2000 Honda Civic
Old Feb 13, 2022
Berteasterly202's Avatar
Berteasterly202 is an unknown quantity at this point
2000 Honda Civic
So my friend has a 2000 Honda Civic he changed his spark plugs we have verified it is in the correct firing order but now the car will not run it idles perfect just under eight hundred RPMs when you hit the gas it bogs down and stalls out
Old Feb 13, 2022
Re: 2000 Honda Civic
what brand?
Honda no like non-OE plugs
Old Feb 13, 2022
Colin42's Avatar
Did you touch anything else? Plugs gapped properly?
timing out?
Old Feb 13, 2022
He says that it was misfiring befor the plug change and the new ngk plugs helped a lil bit but it idles good just under 750 rpms and when you press the gas pedal it boggs down and stalls out
Old Feb 13, 2022
NGK bad for hondas
Old Feb 13, 2022
FRSam's Avatar
Click Here
Originally Posted by sdaidoji
NGK bad for hondas
NGK is what almost all Honda's come with. I use NGK exclusively.
Any engine codes? Check for vacuum leaks.
Old Feb 13, 2022
oh, for some reason I read that as bosch, my bad...
Old Feb 13, 2022
Old Feb 13, 2022
FRSam's Avatar
Click Here
Has he replaced the O2 sensor? That's what a code is for and that'll cause a misfire.
Replace with OEM only. Aftermarket will not work. Denso or Honda brand only.
Old Feb 13, 2022
Apparently the O2 sensor code with pre-existing because the exhaust is broken before the second catalytic converter hes owned the car for about 6 months and never had a problem with the misfiring until a week ago he was driving and it stalled out on him and will not run he thought it was the spark plugs so he's changed them and used NGK plugs which helped the issue a little more cuz now it won't idle just fine but when you press the gas it bogs down and tries to stall out I have a video of what it is doing however this website will not allow me to post the video
Old Feb 13, 2022
Whoever coming in about the NGK spark plugs you are incorrect... as a matter of fact Honda suggest only using NGK V-Power or Denso TT Platinum plugs and I do believe the current day Honda manufactured and distributed with NGK V-Power as their oem plugs
Old Feb 13, 2022
FRSam's Avatar
Click Here
This was addressed previously.
As for the codes, perhaps it's a fuel issue. Certainly not ideal to leave the O2 sensor code, either.
MamaBear2015
Jan 30, 2021 10:31 PM
Pugsley52
Mar 31, 2017 09:47 PM
FordSlayer
Mar 18, 2012 12:03 AM
fseyfi89
Apr 7, 2008 10:31 AM
