Losing coolant
Old Dec 10, 2021
Gonzo's Avatar
Gonzo is an unknown quantity at this point
Losing coolant
Not sure what this is or why coolant is coming out of it. Car keeps overheating and losing coolant as soon as it reached temp. It looks like it's coming from a filtech box attached to the passenger side wall. Please help at a loss!
Old Dec 10, 2021
FRSam's Avatar
Click Here
Losing coolant
The coolant overflow reservoir? Also, start your own thread.
Old Dec 10, 2021
Gonzo's Avatar
Re: Losing coolant
Just did but why is it leaking all my fluid from there? So isn't the res tank by the radiator. I don't see a hose leading from that to underneath the car?
Old Dec 10, 2021
BrotatoChip's Avatar
Super Moderator
Re: Losing coolant
That looks like the A/C drain tube, condensation dripping out is normal. Sure that's where coolant is coming from?
Old Dec 10, 2021
Gonzo's Avatar
Re: Losing coolant
Yes it's definitely coolant.
Old Dec 10, 2021
Super Moderator
Re: Losing coolant
Would a leaking heater core end up draining from there? I honestly don't know.
Old Dec 10, 2021
Gonzo's Avatar
Re: Losing coolant
I'm not that mechanically inclined so it's giving me some trouble. Everytime I put coolant in it end up coming out that hose.
Old Dec 10, 2021
Gonzo's Avatar
Re: Losing coolant
it seemed to happen when I turned the heat on? I ran it for about ten minutes let it cycle twice at least and nothing until I turned it on. Gonna fill up coolant again and try without turning heat on at all.
Old Dec 10, 2021
Gonzo's Avatar
Re: Losing coolant
Still coming out of that hose, no heat, and overheating. Fan comes on and hoses to and from radiator have heat and at times some pressure.
Old Dec 10, 2021
Colin42's Avatar
Re: Losing coolant
If you can't figure this out take it to a shop before you ruin your engine
Old Dec 13, 2021
Super Moderator
Re: Losing coolant
I would think it's a leaking heater core.
ThatD_17
27
Oct 14, 2016 06:58 PM
oceanbreeze
Aug 15, 2013 12:50 AM
cdmx
Mar 12, 2003 11:28 PM
gqsang
Apr 16, 2002 12:31 PM
Pongster
Jan 18, 2002 09:30 PM
