Blowing blue smoke when VTEC hits?
Old Aug 27, 2021
SE7ENZEROTWO's Avatar
SE7ENZEROTWO is an unknown quantity at this point
I just replaced the cylinder head in my civic and it brought up the compression in all 4 cylinders up to 150PSI, but it seems to still burn oil when VTEC engages.
Is that normal?
Old Aug 27, 2021
Re: Blowing blue smoke when VTEC hits?
a new engine would not, but they are almost as old as yourself...
aside from obvious questions, with that information, chase where the oil is leaking into the cylinders. is it coming from up or bottom? or middle?
plenty of parts that could be the issue, you need to investigate, asking is easy
Simple answer is your engine is toast.
Real life answer is open engine and find the leak. Your engine is different from all others, it could be piston rings, cylinder normal wear needing bigger pistons, headgasket, valve seals, etc, etc
Old Aug 27, 2021
FRSam's Avatar
Click Here
You probably have some blow-by when you’re up in the RPMs. That could be due to worn piston rings.
Optimal compression is like 175-180psi so it’s definitely showing signs of age. I wouldn’t worry about it personally unless it’s burning an excessive amount of oil.
Old Aug 27, 2021
The engine has 195k on it so I get it. But it's only when VTEC activates.
That just puzzles me.
Old Aug 27, 2021
FRSam's Avatar
Click Here
I suspect it burns regardless, but it's only noticeable when you're in VTEC (even though VTEC has nothing really to do with it).
It's most likely bypassing at your piston rings. It's more noticeable at high RPM because the engine components are moving much more quickly.
Old Aug 27, 2021
VTEC makes the valves open more, might be exposing worn parts of the valves
Old Aug 27, 2021
Cylinder head is brand new.
hmm
thank you
Old Aug 27, 2021
brand new 1998 engine head?!?
or remanufactured?
new valves?
Jesse Smith
Engine Swaps
21
May 28, 2020 07:19 PM
DsevenEm2
May 9, 2007 01:01 PM
trance4mer
Jun 15, 2004 03:01 AM
kjl0083
Apr 7, 2003 08:51 PM
ZSKCivic01
Sep 14, 2002 06:24 PM
