2000 ex p0420 [solved]
Old Aug 6, 2021
DIYfan's Avatar
DIYfan is a jewel in the roughDIYfan is a jewel in the roughDIYfan is a jewel in the rough
My Son drives a 2000 Civic EX with SOHC VTEC. I think it is a D16Y7 engine. Recently, it threw a P0131 so I replaced the upstream O2 sensor which cleared the problem. However, it later threw a P0420. The car has 165k miles. I ordered a new catalytic converter and am waiting for my Son to bring his car so I can replace the bad cat. Is a worn out catalytic converter common on these cars and has anyone had to replace theirs?
Old Aug 6, 2021
BrotatoChip's Avatar
Super Moderator
re: 2000 ex p0420 [solved]
Catalytic converters will always go bad over time. I would say 150k to 200k is usually when they start going bad.
Old Aug 6, 2021
went bad after 21 years? I would call that a winner
Is this a serious question?
Old Aug 6, 2021
they are designed to react chemically and will have reduced impact overtime
https://en.wikipedia.org/wiki/Catalytic_converter
replaced mine 2002 a few years back. They do wear out.
Old Aug 6, 2021
you can also google "Catalytic converter life"
https://www.google.com/search?q=cata...4dUDCAg&uact=5
Old Aug 16, 2021
DIYfan's Avatar
Replaced the cat and downstream O2 sensor and the check engine light is now gone. Car also seems to have more pep above 5000 RPM. The old cat was visibly clogged with no light shining through. While I was down there I noticed the drivers side CV axle boot failed and exploded grease everywhere so that is the next project.
Old Aug 16, 2021
Colin42's Avatar
Re: 2000 ex p0420 [solved]
Just an FYI if you bought a cheap cat that code will be back in about a year
choocheus
Oct 16, 2021 05:19 PM
Boods
Jul 19, 2006 10:52 AM
gillio215
Jun 4, 2006 08:11 AM
04_CIVIC_HFP
May 15, 2006 08:22 PM
puffdaddy411
18
Sep 1, 2005 09:44 PM
