help me identify what head i have
Old Apr 14, 2021
98civicmem's Avatar
98civicmem is an unknown quantity at this point
i have a 98 civic ex coupe with has a b20b block with a b18 head so i was told, can yall tell me where to look to tell exactly was designation it is for the head ie like b18b head or something i need to buy a distributor thats one reason i need to know i think its just a regular integra LS head. thank you guys for the help, im trying to hunt down the reason for the idle when warm it idles at 1400 rpm and the idle adjustment is all the way to the lowest possible so i researched on the forum and i read alot about vacuum leaks, and the distributor is kinda jerry rigged so i figured id get the right one first any ideas throw them my way
Old Apr 14, 2021
FRSam's Avatar
Click Here
Re: help me identify what head i have
Pretty sure the b-series distributors are universal. The non-vtec ones are for sure, anyway.
Old Apr 17, 2021
Wankenstein's Avatar
High idle most likely isn't related to the distributor. Have you checked ignition timing with a timing light?
The 5th and 6th gen engines idle a bit high from cold to near operating temp so, is the idle at operating temp higher than cold start to warm idle rpm's?
Is the high idle at operating temp present all the time or intermittent?
Best place to start is to make sure the throttle body is clean and the butterfly (flap) is not sticking to either the TB inner bore or the small holes on each side of the inner TB bore the flap connects to/rotates on. Clean those holes, the inner bore, the flap (including outer edge) with brake cleaner, tooth-brush and a rag to dry it. I prefer to remove the TB but you don't have to. Also, there is a possibility of tearing the TB gasket if it's old and brittle.
After cleaning the TB thoroughly spray silicone lube spray on the butterfly flap return spring located on the outer bore of the TB. Also, carefully spray silicone lube on those small holes the flap pivots on inside the TB inner bore.
Check the throttle cable for proper tension and lube it too.
Best test for vacuum leaks is a smoke test (youtube it). Pretty easy to make your own and there are write-ups and youtube's on them.
Old Apr 18, 2021
98civicmem's Avatar
yes sir it idles at a consistent 1300-1400rpm when warmed up and when starting it cold it sits at around 800rpm or so. if you put it in first and ease out the rpms will drop because your lugging it. but i will try cleaning the throttle body as u can tell its a cheap ebay one i didnt buy it it came on the car, and if that doesnt work ill try the smoke test for vacuum leaks. and also idk if i said this or not the idle adjust is all the way to the lowest possible, thank you guys
Old Apr 18, 2021
What is the size (mm) of that Ebay TB bore?
Has it always had this high idle issue since your ownership?
Idle screw adjustment: https://www.google.com/search?q=hond...FNI7nizY43Hh5M
Erocmassacre
May 28, 2019 09:04 PM
obowhunter2
Feb 2, 2017 11:02 AM
CowboyUpPride
May 15, 2009 01:43 PM
ProjectCivicX
Feb 24, 2009 10:38 AM
Captain
Dec 11, 2003 09:37 PM
