Head bolt over torque what now
Old Mar 17, 2021
davidscheiber28's Avatar
davidscheiber28 is an unknown quantity at this point
Doing a head gasket job on a Civic D16Y7 bought a brand new torque wrench (from the hft) turns out the torque wrench was/is faulty (won't even click clamped to a vice) over torqued a couple head bolts before I realized (The bolts seemed to get loose but still seem to be torqued to spec which I verified with a good torque wrench) what do I do now? Do I order a new head gasket and bolts? I'm worried that if I take the bolts out now the aluminum threads will come out of the block.
Old Mar 17, 2021
Colin42's Avatar
Re: Head bolt over torque what now
Fire it up and see if you got lucky, otherwise you're probably going to have to helicoil the block
Old Mar 18, 2021
Thanks for the reply I ended up loosening all the bolts and inspecting The ones I over torqued, they appear to be fine no signs of stretching went ahead and retorqued them to the correct spec I'll see how it goes. The manual actually does recommend loosening and re tightening the bolt if they make noise so hopefully it will be fine. I will double check the head bolt torque after running it a while though.
Old Jul 25, 2022
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
I’m very curious how this may have worked out?
user 8230230
Feb 1, 2021 06:38 AM
gfenderbender
Engine DIY
Dec 8, 2018 01:16 AM
john donovan
Sep 4, 2017 09:54 AM
civcspool
Engine Swaps
16
Aug 17, 2008 05:59 AM
97civihatch
Mar 20, 2006 12:05 PM
