odd starting problems
Old Nov 1, 2020
2civic's Avatar
2civic is an unknown quantity at this point
96 civic
starts right up but will shut off in 30 seconds unless i hold throttle over 2000 rpms for at least 1 min then it will stay running
when it dies it just cuts off like i turned key off
before i found high rpm trick it would die 30 sec then 20 then less till it would only crank
what was also odd was when it got to the point of not starting the spark( while some one was cranking it) was intermittent
won't even start on starting fluid
Old Nov 1, 2020
GolNat's Avatar
Prelude Owner
Re: odd starting problems
What happened leading up to this? Any work done? What do the plugs look like? Have you verified timing?
CEL on?
Old Nov 1, 2020
2civic's Avatar
i bought it with coil bad replaced it
that is all i havent taged it because of i want to find out what is causing problem
it runs fine after you do the starting trick
5spdvroom
73
Jul 25, 2016 07:55 PM
magician
Mar 10, 2016 12:29 AM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
Sethster99
Apr 6, 2013 12:51 PM
adioskate12
May 9, 2006 11:20 PM
