Blue devil flush
Old Sep 23, 2020
Visionator01's Avatar
Visionator01 is an unknown quantity at this point
Blue devil flush
This is a bit different from what the title would suggest.
ive got a 99 EX and we put blue devil's head gasket sealer in it. We later realized it was worse than we thought and replaced the head gasket. We've now realized some of that sealer is starting to get into my radiator and clog it up. We've run a hose through the radiator (forwards and backwards) and that worked for a bit to stop the overheating, but we didn't get everything and I'm not sure what else is in the block. I'm probably going to replace the radiator but I want to make sure everything is out of the engine itself. Is there anything I can do to get it out without having to tear apart the engine?
Old Sep 24, 2020
Colin42's Avatar
Re: Blue devil flush
Nope this why we never recommend using that garbage. Replace everything that coolant goes though, heater core, rad, hoses, block, etc
Old Sep 24, 2020
BrotatoChip's Avatar
Super Moderator
Here are some pics of an engine I had that had stop leak used. On a 7th gen but pretty similar. I spent quite a bit of time scraping that crap out. Got a new radiator, hoses, thermostat, and water pump while replacing the head gasket.
https://www.civicforums.com/forums/3...-problems.html
Old Sep 26, 2020
mac25's Avatar
Dr Krieger of Modification
You could do a test to find a soluble solution
-since coolant is water based water wont work, but you could see if the sealant will dissolve in alcohol or acetone/paint thinner solvents.
if the sealant dissolves, only use the solvent on metal components, not the rad. Or hoses as these may deteriorate over time, as a result of contacting solvents.
jacobeckstein
Aug 23, 2016 10:43 PM
akronoh77
17
Sep 2, 2014 10:16 PM
hondaluv453
Aug 15, 2014 09:38 PM
djstorm100
Jul 31, 2013 11:41 PM
drmcstford
36
Feb 18, 2013 03:42 PM
