Engine rattle during acceleration
Old Aug 27, 2020
OoohCivicLx's Avatar
OoohCivicLx is an unknown quantity at this point
Hey all, good morning!
I will admit immediately I haven't researched the issue too much just yet, however after correcting the failed head gasket on the honda I've noticed recently it's developed a solid rattle/grinding sound especially during acceleration after the car has heated up during the day.
I've noticed the rattle will be consistent on the drivers side of the engine bay even at idle when the ac is cranked up. So I'm wondering will bad pulleys cause this noise? I'm thinking the tensioner pulley or maybe the compressor pulley itself has started to wear out or is loose for some odd reason and causing this rattling sound when it warms up or when the ac is in use. Any feedback or info elsewhere would be amazing! Thanks guys
Old Aug 27, 2020
Re: Engine rattle during acceleration
remove the accessory belts and see if the noise is still present
Old Aug 27, 2020
i'll do my best to get them off, will likely have to be once the car is fully warmed up and hot, that's when the rattling is at its worst
would a bad pulley or tensioner cause a rattling/grinding?
Old Aug 27, 2020
Colin42's Avatar
It might, that's why you need to pull the belts to see if the noise is still there
Old Aug 27, 2020
Will give it a shot then and keep you guys updated.
Fairly certain it's a/c related but we shall see
Alex Willett
Apr 12, 2017 09:09 AM
7thGenSE
Feb 17, 2015 09:01 PM
ntgarwood
Jun 3, 2014 09:00 PM
demonsoliloquy
Feb 22, 2013 07:13 PM
bmboll
Apr 18, 2011 09:00 PM
