spun rod bearing
Old Feb 19, 2020
Reedtech's Avatar
Stoned Mechanic
Reedtech is an unknown quantity at this point
spun rod bearing
So it all started after I started with a ticking noise on cylinder four. Unplugging the wire would stop the ticking and the ticking would happen at about 2500 rpm. One day while driving it happened. Vibrations in the clutch and shifter, loss of power and white smoke comimg from the hood. I pulled over and had it towed home. I just had a moment to drop the pan today to inspect and the rod bearings and they are all tight but cylinder 4 had lots of play. After pulling the cap off I see that the rod bearing above the crank on cylinder 4 spun its self on top of what was left of the bottom bearing. The pictures will speak for themselves. I have even had this car 6 months yet and there was nothing I could have done to prevent this from happening it was just a matter of time. Now to replace the rod bearing and polish the crank. This will just be a temp fix until I can put a new engine in there.
Old Feb 19, 2020
mac25's Avatar
Dr Krieger of Modification
Re: spun rod bearing
Darn, that sucks.
Old Feb 19, 2020
BrotatoChip's Avatar
Super Moderator
You would probably be better off just replacing the engine now rather than waiting. You can find a used one for ~$500.
Don't know what your plans are but polishing the crank usually involves a machine shop, removing the crank is quite a bit of work.
Old Feb 20, 2020
Reedtech's Avatar
Stoned Mechanic
Im gonna do a low mile z6 jdm conversion in a few months. I'm gonna polish the crank with the shoe string method and some memory cloth.
Shotzy
Feb 28, 2018 10:51 AM
AMartin25
Jan 17, 2017 06:45 PM
ineedanswers
Sep 27, 2014 06:09 PM
WannaBFast
May 22, 2005 06:33 PM
CivicPride21
Feb 1, 2005 07:14 PM
