98 Honda Civic will start then won't.
Old Feb 6, 2020
mmaaka's Avatar
mmaaka is an unknown quantity at this point
Hello all
so my 98 civic is throwing me a bone here and I'm getting impatient, first thing in the morning the car will start! I take 1 of my kids to school then come back home then 25 min later I take my oldest to school and car won't start. it cranks but will not turn over. I'm pretty familiar with my cars as I do all the work my self but this one has me in question.
-installed a brand new battery.
-put on new battery terminals
-changed out the rotor cap
- changed the rotor
-replaced spark plug wires
-replaced the main relay switch
- there is spark on all plugs
-the fuel pump works perfect
- changed the fuel filter
the dam thing will work and I can start it 12 times in a row and won't lose power in the battery. I drive to the store and BAM she died in the parking lot. then ill jump it and sometime it starts then most time it won't then 20 min of trying it starts up like nothing ever happened and ill drive home and turn car off and on multiple times and no issues. if I make an attempt to leave later then the car won't start.
does any one know the issue. all the items I installed were done at the same time so Im out of ways to fix the issue.
Old Feb 6, 2020
mac25's Avatar
Dr Krieger of Modification
Re: 98 Honda Civic will start then won't.
If you have a good obd2 scanner you can check the fuel trims while trying to hot start it.
if not get a cheap amazon obd2 for your phone and download the Torque app. That way you can see trims.
First thought would be the temperture sensor is dying. It changes the fuel trim for different temperature ranges.
I doubt you'd have a spark related issue, regarding engine temperature.
Old Feb 6, 2020
mmaaka's Avatar
I put on my OBD2 scanner on and only code that came up is p0505. " IDLE CONTROL SYSTEM MALFUNCTION"
but no check engine light is on
Old Feb 6, 2020
mmaaka's Avatar
and idle air control system.
Old Feb 6, 2020
SkittlesNbits's Avatar
SkittlesNbits is an unknown quantity at this point
Originally Posted by mmaaka
Hello all
- changed the rotor
Its the MAIN relay under your dash by your steering Column, Symptoms would be starting when its colder in the car when the cabin of the car gets hotter it wont start. The soldering on the main relay has started to fail and started causing problem. The MAIN relay is like a $60 part from the dealer. I know it sound to simple to be the problem but im 99% sure this is the problem i have fixed 2 hondas with this problem and in both instances a "mechanic" couldnt narrow it down.
(EDIT) On my 2000 civic ex the main relay i believe was behind the glove box If i remember correctly
Old Feb 6, 2020
mmaaka's Avatar
I have changed that already last night. one my list of items I've done I stated I already replaced the main relay switch
Old Feb 7, 2020
sorry some how I over looked that
Old Feb 10, 2020
Wankenstein's Avatar
Do a coil (inside distributor) arc test as show in video. Can use a long handled screw driver to ground instead of probe shown in video. If the coil dies during the test that's a good thing because it proves it's weak anyway. If the coil needs to be replaced use a genuine oem (either TEC or Hitachi.. check the name on the present one) .
Old Feb 11, 2020
Next time it won't start bang on the starter a few time then try starting it..
Carry a hammer to knock on a piece of pvc pipe or wood to the starter and solenoid housing.
Crabulon
Sep 7, 2016 08:17 PM
screamsayonara
Aug 7, 2013 09:05 AM
torok
Jun 9, 2012 06:41 PM
c4harpe13
Mar 15, 2010 07:43 PM
red98ex
15
Mar 10, 2009 12:32 PM
