P0335 code on and won’t rev past 3500rpm
Old Nov 10, 2019
Isaacaquino's Avatar
Isaacaquino is an unknown quantity at this point
Hello everyone I have a 98 EX that once it warms up the check engine light comes on and won’t rev past 3500 rpms I already changed the crankshaft position sensor I also made sure the timing is correct I also replaced the ecu and it still does it if someone has gone through this and knows what I need to do to fix it I would appreciate it. Thanks for taking the time to read
Old Nov 10, 2019
Colin42's Avatar
Re: P0335 code on and won’t rev past 3500rpm
There's a service bulletin somewhere about those wires getting chewed up by the belts, maybe check that?
Old Nov 10, 2019
I did they are fine still wondering what could be the problem
Old Nov 10, 2019
Colin42's Avatar
Did you put an OEM sensor in?
Old Nov 11, 2019
No I got it at autozone
Old Nov 11, 2019
Colin42's Avatar
Go put in an OEM sensor and see what that does
rae_man
Sep 2, 2020 12:13 AM
cg95660
Nov 12, 2017 08:38 PM
Rhonda Dupree
Aug 1, 2017 10:55 PM
GeraldRuss
Jan 18, 2017 07:23 PM
thesob40
Nov 2, 2008 12:02 PM
