Missing at idle only when warmed up
Old Feb 16, 2019
dgm's Avatar
dgm
dgm is an unknown quantity at this point
1996 Civic, Automatic
In the last 2 days, the engine has started missing at idle when fully warmed up after driving for more than about 20 minutes. It is not surging, it is missing. When not missing, it idles perfectly. If you let the car cool down for about 30 minutes and start it, it runs perfectly until heated up again.
Check engine light has NOT come on.
Code reader shows no stored codes.
I took off the air cleaner, and the throttle valve and intake looks perfectly clean.
I cannot find any vacuum leaks.
Distributor cap does not show any cracks - I've looked carefully.
Since it runs fine until fully heated up, my thought is that it isn't spark plugs or wires from distributor
Car has under 60,000 very easy miles.
I would appreciate suggestions on where to start looking. Thanks.
Old Feb 16, 2019
dgm's Avatar
dgm
Re: Missing at idle only when warmed up
Since it showed no stored codes, I took photos of the live data when idling just in case it is helpful:
Old Aug 17, 2020
oldntired's Avatar
oldntired is an unknown quantity at this point
I have a similar problem on my 2000 EX D16Y8. I'll let you know what I find.
In a past car, I had an '06 Ford Escape that had a rusted actuator on the IAC valve. I'll be looking at that myself on the Civic.
CSIT_Civic
Mar 14, 2018 03:29 AM
Baconator
18
May 10, 2015 01:31 AM
allnet0300
Aug 18, 2014 06:25 PM
FrozenCaveman
Mar 11, 2014 02:21 PM
HommeDeBois
Aug 7, 2011 08:19 AM
