Electrical Post your Electrical issues here!
98 LX Model flashing interior lights [solved]
Old Apr 24, 2021
trashman95's Avatar
trashman95 is an unknown quantity at this point
Post 98 LX Model flashing interior lights [solved]
My 1998 Civic LX has a weird issue where any electrical input (brake lights, turn signal, hazards, ac, etc.) causes what I would assume to be a relay begin clicking. Followed by all interior lights (if on) to begin flashing with the same rhythm as the clicking from the suspected relay. Also, the dash lights do not turn on, instead they will only illuminate from previous said causes, then it will stop after about 5-10 seconds. Any information would be highly appreciated, and I apologize if something similar has been solved. I tried searching for this issue but it seems sadly unique. Cheers
Old Apr 24, 2021
Colin42's Avatar
re: 98 LX Model flashing interior lights [solved]
Check for melted/hacked wiring, something is touching something that it shouldn't. Also when it's acting up try to figure out what relay is clicking, might help you narrow the search for the bad wiring
Old Apr 24, 2021
trashman95's Avatar
I'll look into that. I did notice it looked like the previous owner has installed some sort of sound system so it's probably caused by something along those lines. I'll post an update if I find anything else out. Thanks
Old Apr 24, 2021
trashman95's Avatar
Well after digging around under the dash I followed the clicking back to this little black box that I believe to be an aftermarket alarm (that doesnt even work) that the previous owner installed. Upon removing the orange fuse all clicking stopped. Going to completely remove it and see how that works out.
Old Apr 24, 2021
Colin42's Avatar
Yep, pull all of that out and fix any spliced wiring correctly.
Old Apr 24, 2021
trashman95's Avatar
Thanks for the help Colin, appreciate it
FearWRX
Feb 16, 2021 08:27 PM
pspmhofer
Electrical
Aug 19, 2013 04:23 PM
johnny626
Sep 15, 2010 10:13 AM
Chickapea
Aug 8, 2002 02:21 AM
Liewy
Jul 19, 2002 12:50 AM
