Electrical Post your Electrical issues here!
Fuel gauge stuck in Full [solved]
Old Jun 14, 2020
Cesar27alexis's Avatar
Cesar27alexis is an unknown quantity at this point
I'd like to know if anyone has had this problem and how they fixed it
Old Jun 14, 2020
Colin42's Avatar
re: Fuel gauge stuck in Full [solved]
Check the sending unit
Old Jun 14, 2020
It's already been checked, put the whole needle down to empty and at the time the car started it went up again and then it stays full
Old Jun 15, 2020
Colin42's Avatar
So you messed with the needle in the gauges and not the sending unit in the tank?
Old Jun 15, 2020
Explain to me bro
Old Jun 15, 2020
Explain to me bro
Old Jun 15, 2020
Colin42's Avatar
Read:
https://itstillruns.com/fuel-sending...k-4909834.html
So if you move the arm on the sending unit (removed from the tank but still connected with the key on but engine off) the gas gauge should go up and down.
If it doesn't then test the sending unit. If the sending unit tests good, then either there's a break in the signal wire to the gauge or the gauge is bad.
Old Jun 15, 2020
yeah man, the fuel sending unit is in the tank, usually part of the fuel pump assembly. It's essentially a float... operated potentiometer. Change in resistance is equivalent to fuel level. Sends a signal to the cluster so the needle can point to indicated fuel level.
If you physically messed with the needle, however, you may have messed up calibration
Old Jun 15, 2020
Read:
Tomorrow I'll try with a friend if it's the fuel gauge
Old Jun 29, 2020
Last week i test a different dash and the needle start moving to the position, so i decided to buy a new dash and problem solved.
Thank yoy guys for al the tips and information.
Old Jan 2, 2022
Spaz253's Avatar
Spaz253 is an unknown quantity at this point
just picked up a new/used cluster and put it in now the fuel gauge goes to full, is there a way im supposed to reset it? not sure what to do i dont wanna have to pay to have it fixed if i can figure it out.. plz help, we put the original fuel gauge in the new/used cluster and that one goes to full now it worked just fine in the original cluster.. how do recalibrate it?
Old Sep 5, 2023
virtsantos's Avatar
virtsantos is an unknown quantity at this point
Maybe I can help you.
I've had a problem with the speed cluster, so I disassembled the quadrant, resoldered all the solder points on the outside circuit board, and it solved my problem with the speedometer but in the assembly process i snapped one of the screws of the fuel gauge and when i start the car always showed me full tank.
I´ve dissasemble again and check the fuel gauge support of the broker screw, the copper fillement snaped you can fix that by soldering the little copper filament again no neew to buy new gauge, be extra carefull with that screw on assembly.
So if you have probelms with your gauges
1º- resolder all the outside circuit board joints
2º-Check your gauges screws supports for snapped copper wires ,if yes them sold them, be extra carefull on assembly because they will rotate again
the tinny copper filament spnaped , just take one from old cable and resolder the screw joint to the copper bobine
Hope it helped
Old Sep 5, 2023
Spaz253's Avatar
Hope it helped
Thanks we ended up taking cluster to a shop and they fixed, unfortunately we dont have that car anymore it was stolen from the mechanic at a gas station
Montegoody
Electronics
Sep 27, 2022 12:40 PM
s7khan
Transmission
Mar 6, 2013 10:27 PM
gordon555
Dec 28, 2011 10:29 PM
MelJ
Mar 20, 2011 04:45 PM
