Electrical Post your Electrical issues here!
Weak cold startup, takes multiple startups to stay on.
Old Nov 12, 2019
Eddie Castro's Avatar
Eddie Castro is an unknown quantity at this point
Looking to find out how to get my car to start up strong in one crank and stay idling.
Old Nov 12, 2019
Colin42's Avatar
Re: Weak cold startup, takes multiple startups to stay on.
Need more information.
Cranking slow? Normally?
Check engine light on?
Lots of coughing and sputtering?
Old Nov 19, 2019
99stockcivic's Avatar
99stockcivic will become famous soon enough
As said above, not enough info to really give specific advice. You need air, fuel, and spark. If it's slow, some guesses are to start with the basic, change plugs, wires, distributor cap and rotor. Then make sure you have a good battery, and make sure you have a good ground strap.
If it has trouble idling, then perhaps it's air, so idle valve needs replacement or cleaning.
Tell us what you have done so far to try and fix it.
Old Dec 9, 2019
It starts with very low rpm dies after I let the key turn back but if I hold the key turned to the start position it kind of warms it up enough to hold an idle, sometimes i will give it gas to get it to warm up and start and it will sound like popping in my cylinders, after about 15 minutes the idle will go up from under 1k to around 1.5k rpms. Check engine light is on, I’m sure there are vacuum leaks not sure exactly where to start. I haven’t cleaned my fast idle yet or tightened it down
Old Dec 9, 2019
Wankenstein's Avatar
Originally Posted by Eddie Castro
It the idle will go up from under 1k to around 1.5k rpms. Check engine light is on, I’m sure there are vacuum leaks not sure exactly where to start. I haven’t cleaned my fast idle yet or tightened it down
As always, Puffinblunts recommends a "smoke" test to find vacuum leaks. Rev up your doobies:
Old Dec 9, 2019
Colin42's Avatar
What's the engine code? Pxxxx
IAC could be dirty/sticking/bad
Timing could be off
honudad
May 21, 2016 04:35 PM
fearfact
Nov 20, 2012 01:34 PM
swpowe
Dec 26, 2009 05:21 PM
mr_a
Jan 18, 2009 04:41 AM
becky23
Engine start problems
May 1, 2007 08:46 AM
