Loose E brake
Loose E brake
Hi,
I just replaced both shoes in the back and my ebrake is barely tight enough to hold the car in place. Everything works, I just dont know why I cant tighten my e brake, Its about 15 clicks, or pulled the whole way. It seems to be the same as it was with the old shoes. Everything works, it was put back together correctly. Any suggestions to what to check?
Thanks,
Thanks,
Re: Loose E brake
Yes I have tightened it. The nut is in the same place as with the old shoes that were worn down almost to nothing I have loosened the nut and tightened it. That doesnt make sense either being new shoes.
23
Oct 30, 2017 08:36 AM
Junquito89
Oct 23, 2015 08:39 AM
Junquito89
Oct 2, 2015 11:06 AM
