Deer damage 2004 si
Old Nov 25, 2023
Dan 1's Avatar
Dan 1 is an unknown quantity at this point
Angry Deer damage 2004 si
On my way home a deer hit me in the drivers side head light at 75 mph
I am now looking for these parts in silver if possible: Hood, left fender, grill, head light, drivers side door glass. At least inner fender plastic.....probably more when i get into it.
If someone has these for sale or knows a good resource, that would be very helpful.
I live in S.W. Missouri USA
Thanks
Old Nov 25, 2023
Re: Deer damage 2004 si
car-part.com for nearby scrapyard search
Old Nov 25, 2023
FRSam's Avatar
Click Here
I'm guessing subframe damage at that speed. More than likely a writeoff.
Old Nov 25, 2023
Dan 1's Avatar
I am going to try to fix it. It runs and drives. It go into the battery, and I thought the side glass was out but it rolled itself down. Wires grounded at the door jam I'm sure.
Old Nov 25, 2023
FRSam's Avatar
Click Here
No idea what the laws are in MO but you’d potentially have issues here in Canada. If there’s any tweak in that subframe around the headlight, its structural integrity gets a bit dicey.
Old Nov 26, 2023
Dan 1's Avatar
It's not too strict here, I am having a local body shop take a look at it.
I will see if it's worth it, it still has a lot of life left in it.
If the body shop says the subframe is twerked too much I will sell it as is to someone who needs one.
I've only seen two in my area since 2017.
Old Nov 26, 2023
FRSam's Avatar
Click Here
Roughly 35000 were sold into the US, so they're certainly not common cars. I still see a few where I am, though I suspect I'm in a much more densely populated area.
Old Aug 22, 2024
Dan 1's Avatar
We have had a few financial set backs since the deer and honda got together, thanks to the help I have gotten here I have gathered up all the parts accept a drivers/ left side window regulator, one cable is broken, track is good motor is good, 6 pin auto up. I cannot find one. I may end up making the cable.
I feel I there should be one setting in a yard in NE US somewhere, any ideas?
Old Aug 22, 2024
BrotatoChip's Avatar
Super Moderator
Amazon Amazon
Old Aug 23, 2024
Dan 1's Avatar
Well that was easy ! Thank you, I did look on Amazon and Ebay, Ebay seemed expensive most parts were used and in the UK. On Amazon all I seemed to find was the standard civic of the same year.
Thank you very much !
Old Aug 23, 2024
Super Moderator
I used RockAuto to look at options, then Google searched the part number/brand. Now you know my secret.
Old Aug 25, 2024
Dan 1's Avatar
I almost ordered this today but it is in fact the wrong one. And the seller got some sketchy reviews as well. Thank you anyway
Old Aug 25, 2024
Dan 1's Avatar
This one about $200
Old Aug 25, 2024
Colin42's Avatar
I'd just order it from rockauto
Old Aug 25, 2024
Dan 1's Avatar
I was hoping to get it for less than 200. That's the real problem.
The one for the standard civic is $40 even a used one from the UK is 100 and it doesn't have auto up.
Old Aug 26, 2024
Dan 1's Avatar
I did find it on rockauto, they sell the cable mechanism separately (which is what I need) from the motor and gearbox unit, Thank you
Old Aug 26, 2024
Super Moderator
It does look like the one I sent is for the non-Si. Rockauto has it listed wrong.
Old Aug 27, 2024
Dan 1's Avatar
Yeah me too Rockauto probably doesn't have it either. As I was getting ready to pull the trigger on this purchase I noticed the cables looked different in the picture.
I found the OEM part numbers at the bottom, they don't match. Dang it !
gchant
Oct 17, 2012 10:32 AM
J.murray
Mar 16, 2007 12:42 AM
Jesshirekat
Mar 15, 2007 11:16 AM
Ronnie K
Nov 2, 2004 05:06 PM
