2002 Civic Si 2 dr coupe
Old Aug 20, 2019
Dreamon's Avatar
Dreamon is an unknown quantity at this point
I am having an issue with the driver side window. It will go down, but when you activate the switch to move it up, it moves about 2 inches and stops. Activate the switch again it goes up and stops. Sometimes it will close the last 5-6 inches, other times you have to keep pulling the switch.
I followed a video on resetting the switch, but it didnt work.
A new switch is around $300, so I bought a used one thinking it was a switch problem.
Anyone else have a similar problem? Any suggestions? Thank you.
Old Aug 20, 2019
Slumpertcivic's Avatar
Re: 2002 Civic Si 2 dr coupe
My first thoughts are the tracks need to be cleaned and greased. Also possible the window motor itself has developed a flat spot and is triggering current limit safety in the switch.
If you have aftermarket tint on the window all the way to the edge it makes it even harder.
06 EX Mild Mods
Electrical DIY
Feb 23, 2019 06:04 PM
waco
Dec 31, 2018 12:43 PM
2HondaCivics
Jun 19, 2015 12:06 PM
Nameless
Jan 13, 2006 09:26 PM
Ed
Aug 12, 2005 10:53 PM
