ever change sunroof seal?
Old Oct 26, 2009
brian02's Avatar
brian02 is an unknown quantity at this point
HI all
Anyone ever change a sunroof seal ( around the glass) on a 02 ex, or any civic? How hard is it? Where do u get a new seal at?
thanks
Old Oct 26, 2009
Re: ever change sunroof seal?
i think dealer is the only place, or junkyard. never changed it myself tho. i think it just pulls out of the roof area?
Old Oct 27, 2009
reyesvazquez's Avatar
reyesvazquez is an unknown quantity at this point
i try to get mine replace, I call every autopart around and they say they dont have it because the rubber seal is attach to the glass part, at honda dealer they ask me 450 for the damm moonroof!!!
Old Oct 28, 2009
yeah the rubber may be part of the glass. i tried to pull mine off to see, but it wouldnt budge. in which case you need a whole glass. have you checked ebay or junkyard?
Old Nov 27, 2009
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
is the seal broken or is your sunroof leaking?
if the seal isn't physically cracked and broken, you might not need to replace it because it's not water tight anyways...the car relies on the gutter system to keep water out of the car. if the gutter drains are clogged, the moonroof will leak
Old Jan 15, 2020
Ykc3590's Avatar
Ykc3590 is an unknown quantity at this point
my 02 civic leaking from rear roofr.
Originally Posted by brian02
HI all
thanks
. my 02 civic has a roof leak at the rear L/ H pillar behind driver try to clean the passage run from the sun roof towards rear pillar but. negative any one has any suggestion. please
Old Jan 24, 2020
Ykc3590's Avatar
Re: my 02 civic leaking from rear roofr.
i have exactlysame issue but no help yet still try to find sunroof seal if i can
Old Jan 24, 2020
BrotatoChip's Avatar
Super Moderator
You just quoted yourself
The sunroof seal is always going to leak a little, that's why there is a drain at each corner. As long as the seal is still in one piece it is likely okay. The only way to find a leak like this is going to be having someone spray the car down while you're inside trying to narrow down the source.
Old Jan 25, 2020
Ykc3590's Avatar
just try to put water ,so the small strip run on the side of the roof is leaking some how i spill water bottle on the strip above LH door and went in to see the leak and yes its coming out from the rear wind shield some how and entering to roof area behind the driver now just want to see if the welds r open oe the rear wind shield rubber seal is worn out. thanks
Old Jan 25, 2020
Colin42's Avatar
Drain tubes are probably clogged
dnmacdon
Aug 30, 2016 10:05 PM
Dakota21601
Aug 18, 2015 08:41 PM
wingnut
Aug 30, 2009 06:44 PM
soarintothesun
Jun 5, 2008 11:19 AM
valenzuela
Jan 17, 2007 10:36 PM
