Door Lock is broken
Old Feb 24, 2006
x.X's Avatar
x.X
x.X is an unknown quantity at this point
Door Lock is broken
Hi, everyone
I have a slight problem my keyless entry does not work for my driver's side door. Currently, I have to use my key to open it which I find it a pain in the ***. and Honda wants to charge 52+tax/30mins to take a look at it?. I know its not the battery problem on the remote because the passenger side open.Someone said it had to do with the motor or some bar. Is it easy to open up the door panel? Did anyone have this problem before ? Any help would be great. Thanks in advance
K
Old Feb 24, 2006
streetglower's Avatar
your door lock actuator on the drivers door is bad. it is actually pretty easy to replace. I had the same problem along time ago and I purchased the door lock assembly from www.hondaautomotiveparts.com for around $50 and took about an hour to install. Here is the DIY for it
http://www.7thgencivic.com/forums/sh...+lock+actuator
Old Feb 24, 2006
Ricky's Avatar
Ricky is an unknown quantity at this point
check your fuse first then check the inside of the door what going on in there then maybe it's the acuator i have 60'000 and mines is ok
Old Feb 24, 2006
there is no seperate fuses for each door actuator. there is only fuses that control the keyless reciever unit and mulitplex control unit. if a fuse pops, none of the doors will work.
Old Feb 24, 2006
DDragon7's Avatar
Funny thing, same thing happened last week on my dirver side lock and didnt open or lock when I pressed the keyless entry in the morning, but it worked in the afternoon, I figured it was fozen or something
Old Feb 26, 2006
noooorb's Avatar
noooorb is an unknown quantity at this point
same thing happened to my civic.
Sep 26, 2023 06:44 PM
17
Jul 23, 2015 11:48 PM
breanna_17
Jul 21, 2015 04:01 PM
ballmich
Jul 9, 2015 11:59 AM
Spanky4269
Jul 5, 2015 09:40 PM
