water inside car - windshield help
Old Mar 14, 2005
slvrcivic's Avatar
slvrcivic will become famous soon enoughslvrcivic will become famous soon enough
Exclamation water inside car - windshield help
anyone ever have water - moisture inside your vehicle - on the windshield?
I did for the first time. It wasn't on the dash at all, just on the lower portion of my windshield, and I can't explain it. Temp changes?
anyone every had this happen, or do I need to speak with honda?
Old Mar 14, 2005
slvrcivic's Avatar
bump
Old Mar 14, 2005
slvrcivic's Avatar
c'mon now...... no one has an opinion or experience?
Old Mar 14, 2005
teampointless's Avatar
Ultimate Member
bad seal around the windshield...
Old Mar 14, 2005
I've had that a few times when the temp changed and humidity did stuff. As long as it's only once in a while...you'll be fine. As long as it's just moisture.
Old Mar 14, 2005
slvrcivic's Avatar
http://www.7thgencivic.com/forums/sh...d.php?t=168924
so back to this thread posted by me? Others said they had the same issues. Are they all about to see leaking as well?
Old Mar 14, 2005
Ultimate Member
that seal is probably letting in just enough humidity to be visible with the temperature changes.
Old Mar 14, 2005
Well the car isn't really air tight. I mean outside air can easily get in, just by opening the door. Try running the AC for a while on the freeway, then go home and quickly shut the door. See if it still does it.
Old Mar 16, 2005
Daemones6's Avatar
Daemones6 is an unknown quantity at this point
Windshield seal. Mine does the same thing, especially if it rains all day.
Old Mar 8, 2019
dbailey's Avatar
dbailey is an unknown quantity at this point
Re: water inside car - windshield help
Ever source that leak? I realize this thread is ancient. The moisture on inside of windshield was water evaporating from the leak and depositing itself on the windshield. That's what cued me to my leak and can't find where it's coming from. Removed fender, used almost a tube of seam sealer in multiple places inside and out and poured water all around the area and no leak. Let it sit in the rain and it leaks. Even put brand new cowls on it and still leaks. Driving me nuts!
grdprx
Jun 29, 2019 12:18 AM
dbailey
Exterior
Apr 21, 2019 09:36 AM
gh0st
Detailing
Feb 2, 2005 06:48 PM
KalliGarri
Feb 4, 2004 08:25 PM
eye_see_you
Detailing
Nov 11, 2003 02:57 PM
