Whine/groan on first acceleration
Hi guys,
I've had my Civic for about a year now, and while I've managed to chase down most of the rattles and shakes, there's still a noise that completely confuses me. The Civic is a automatic 02 ex coupe w/ d17a2, 160k miles.
When I first pull out from my driveway/work, it makes a low whine/growl noise that sounds like a motor being spun by hand. Lasts for just one second and goes away. It doesn't happen pulling from any subsequent stops, only after starting the engine. It does not seem to matter if the engine is hot or cold when started. Every first pull sounds this way (eg. still hot leaving gas station). This leads me to suspect the starter or solenoid, but I don't have any idea how to check that further- they have normal electrical resistances and seem to work well even in cold weather.
I had all the axles and wheel hubs replaced this year and it hasn't made a difference in the noise. Ditto for tb and components. Oil changes are very clean and do not change the pitch/tone of the noise. Suspension was completely redone last year by the previous owner. I've had all the scheduled and some unscheduled maintenance done up to 160k, and my drivetrain feels like it's in otherwise good condition for the age. Great mpg and no fluid consumption. Has anyone else had this problem? Is there anything else I can do to check the function of the engine bearings and starter to rule them out?
Re: Whine/groan on first acceleration
Sorry I can't get a better clip, it's pouring rain like always here. Nonetheless it's pretty loud. The clicks are my backup cam turning on/off.
ABS pump......? If so, that would be normal.
ONE time after startup......the first time you reach a certain low speed (maybe 4 mph, maybe 9, i don't remember specifics) the ABS pump motor cycles on for about one second as part of its self test routine.
It might be mentioned in the owners manual too.
"The ABS control unit checks the pump motor
operation during initial diagnosis when the vehicle is
started. You may hear the motor operate at this time,
but it is normal."
Thank you for the suggestion! I pulled the abs fuse and it doesn't make that noise without it. If that is normal operation, then I'm fine with it.
It may just be a little louder in my case due to worn brake shoes, they're due in less than 5k.
15EXCoupe
Jul 30, 2015 12:59 PM
Sabre_TypeR
Aug 4, 2007 06:42 PM
Stayinstock
Feb 11, 2006 09:41 AM
tibumarine
Jan 20, 2006 06:35 PM
supz
Sep 8, 2003 04:59 PM
