General Post issues, questions that are not in the other sub-forums
VSS - Troubleshooting
Old Jan 7, 2019
iSamoStefan's Avatar
iSamoStefan is an unknown quantity at this point
Vehicle Speed Sensor: Diagnoses/Symptoms
2002 Civic Ex, D17A2, 5 Speed Manual
1) Rebuild Engine
2) Speedometer doesn't work and check engine light P0500
3) Wiggle some stuff
4) Speedometer jitters, doesn't really work though
5) Remove VSS, plug in cable good and firm
6) Speedometer works!
7) One week later...
8) Issues when hard accelerating, jitters return.
9) Wiggle some wires
10) Speedometer stops working completely again and check engine light comes back.
11) Wiggle wiggle wiggle.... Nothing
So am I looking at a connector problem, or is the sensor the culprit(maybe banged up during rebuild?)?
My gut tells me its the wiring harness connector. I could just gut one from a junker and solder it on mine.
Hoping someone has a troubleshooting step to try so I don't just throw parts at it or waste time splicing a new connector.
Excerpt from the factory manual.
Vehicle Speed Sensor (VSS)
The VSS is driven by the differential. It generates a pulsed signal from an input of 5
volts. The number of pulses per minute increases/decreases with the speed of the
vehicle.
Old Jan 7, 2019
GolNat's Avatar
Prelude Owner
Re: VSS - Troubleshooting
I would check continuity from the sensor harness back to wherever the signal goes.
Old Jan 7, 2019
Can I measure as far back as to ecu area where everything plugs in under the glove box? I know there's a good ground and that one post was reading 12v and the other was like 5v or something. I measured with the battery turned on. I know this points straight at the sensor but i'm not sold.
Old Jan 7, 2019
Colin42's Avatar
Try spraying like half a can of electrical contact cleaner in it​​
Old Jan 7, 2019
You really are helping prove how poorly I wrote everything up in my post lol. I did that, to both ends, pretty damn clean in my opinion. Good points keep them coming please
Old Jan 8, 2019
Slumpertcivic's Avatar
vss sensor, failing ECU, or broken harness wire..
a pigtail and 3 10foot wires and a couple inline splices and you could easily rerun a new “harness” to the sensor.
Have you tried unplugging the vss sensor and reading the codes then?
Old Jan 8, 2019
No I actually havent unplugged the sensor to see if the problem is similar. That's a great tip though that will be tried. Thing is that the plug is so rough that it's hard to put on and take off. That's part of the reason for thinking its the problem. I want to know how far upstream I can check for continuity..
honda200192
Apr 5, 2015 09:40 PM
ryrex02
Dec 22, 2010 09:03 PM
zsteelers30
Oct 10, 2010 07:28 PM
Running Riot
Buy, Sell, & Trade - Archive
Feb 20, 2009 11:02 AM
droidekaus
Mar 14, 2002 06:37 PM
