2012 locks won’t open with key! [solved]
Old Jan 19, 2023
Tday99's Avatar
Tday99 is an unknown quantity at this point
My 2012 civic door locks will unlock with the key fob but will not unlock manually with the key in the door handle. The key will turn easily left and right so is not a frozen cylinder. Has anyone had this problem?
Top Answer
Jan 19, 2023
Colin42's Avatar
Colin42
re: 2012 locks won’t open with key! [solved]
Pull the door panel off and see if the lock rod is still attached
Old Jan 19, 2023
Colin42's Avatar
Old Jan 24, 2023
Tday99's Avatar
I figured out the issue. It looks like the previous owner of the vehicle tried to use a slim Jim or coat hanger to open the door. The arm on the end of the lock cylinder was dislodged so it did nothing. I pulled the lock assembly and got it installed properly. Attached is a picture of what was dislodged.
celluloidheros
Electronics
Aug 15, 2022 05:13 PM
grgdotson
Electrical
Jul 23, 2019 08:47 AM
kingrat
Dec 9, 2015 05:34 PM
NoH
Electrical
Apr 2, 2015 11:53 PM
