Electronics Post information/questions/Issues about Electronic parts here.
Cruise Control is weird.
Old Sep 21, 2022
Lefty2053's Avatar
Lefty2053 is an unknown quantity at this point
Every time I use Cruise control it has hic-ups. It has surges and drops in power. Doesn't do this with it off. Does anyone else have this kind of problem with theirs? It isn't constant only here and there. Maybe once every minute. It does seem to go away after driving for a while.
Old Sep 21, 2022
Colin42's Avatar
Re: Cruise Control is weird.
What car do you have?
Old Sep 21, 2022
Lefty2053's Avatar
2009 Civic LX
Old Sep 21, 2022
Colin42's Avatar
Auto or manual?
Those have an e throttle right?
Most likely a problem with that.
No check engine light? Or any other lights?
Tires all the same and at the correct pressure?
Old Sep 21, 2022
Lefty2053's Avatar
Don't know what you mean E throttle. All tires are brand new and Alignment was done when I bought them. Automatic.
Old Sep 21, 2022
Colin42's Avatar
Instead of a throttle cable there's a motor that controls the throttle. It also controls the cruise control
Old Sep 21, 2022
Lefty2053's Avatar
OK, I guess I just won't use the Cruise. Drives fine when I don't.
Old Sep 22, 2022
Lefty2053's Avatar
OK so if the E throttle goes out where would someone find one as there is no listing for any such thing? No E-throttle is listed anywhere on the internet.
Old Sep 22, 2022
just look for throttle body. It's just that it does not have a cable between the throttle body and the pedal.
don't just go buying parts, have it diagnosed!!!
Old Sep 23, 2022
Lefty2053's Avatar
I do know what a throttle body is but OP said E-Throttle and I can't find anything called that. So let me get this straight. When I push down on the throttle/Gas peddle it sends a signal to the throttle body and moves it electronically. Or is it somehow connected to the Throttle body?
Old Sep 23, 2022
yes, it's a signal.
Old Sep 23, 2022
Colin42's Avatar
Go take a look under the hood
Old Sep 23, 2022
Lefty2053's Avatar
yes, it's a signal.
Thanks, so in my case somehow that signal isn't being sent correctly or the Computer is acting up I would guess. The car runs pretty well except for the Cruise control and only for the first 15-20 minutes. After that, it runs well.
01civictune
Aug 26, 2009 12:47 PM
i8dabomb
Dec 15, 2005 11:57 PM
civicman10
Aug 16, 2003 10:26 AM
IncaCivic
May 23, 2002 10:55 PM
bhaz413
May 17, 2002 08:25 PM
