Electronics Post information/questions/Issues about Electronic parts here.
ECU replacement
Old Jan 18, 2021
angelinwhight's Avatar
angelinwhight is an unknown quantity at this point
ECU replacement
My honda civic 2007 japan ECU got burnt, and I replaced it with another 2 different ecu with similar part number 37820-RNA-Y84-47820-121664 engine not reving after the replacements. Later I got another one with different part number the engine rev but idle rough. Please what can I do.
Old Jan 18, 2021
Re: ECU replacement
what is the original ECU part numbers?
What are the replacements?
Old Jan 18, 2021
Re: ECU replacement
37820-RNA-Y84-4780-121664
above is the original part number
Below is the replacement part number
37820-RNC-Q56-4772-108370
Old Jan 18, 2021
Re: ECU replacement
google can't locate anything on the original ECU...
Check:
Engine code - Should be around where the engine mates with transmission. Should be a R18 or R16 something
you will need to find matching ECU for it.
Manual or auto trans will matter, ECU controls auto trans. CVT or traditional trans will matter as well
https://en.wikipedia.org/wiki/Honda_R_engine
Old Jan 23, 2021
Re: ECU replacement
[QUOTE=sdaidoji;4783538]google can't locate anything on the original ECU...
Check:
Thanks I've gotten another ecu And it works fine.
Old Jan 23, 2021
Re: ECU replacement
So two faulty ECU's?!?
ivane_707
Apr 9, 2012 01:11 AM
6thgencivic908
Apr 14, 2010 07:57 AM
Silverphantom
Sep 5, 2003 01:46 AM
wcsjunior
Jan 29, 2003 03:14 PM
SuperCivic2k1
Mar 26, 2002 07:25 PM
