resetting check engine light
Old Apr 19, 2003
01EMCVC's Avatar
01EMCVC is an unknown quantity at this point
i need to know how to reset the check engine light, i had to drop my tranny(auto) to uprgrade my torque converter, went with a JMO torque converter, great people by the way, but now since i had to unplug my reverse light from the tranny and my odometer/speedometer plug the check engine light is on and i know it's because of the unplugging because my car drives great and shifts snappier than before can anyone help?????
Old Apr 20, 2003
Macfay's Avatar
Macfay is an unknown quantity at this point
unplug the battery and leave it for 15 minutes...and plug it back on...
Old Apr 20, 2003
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
That's not gonna do it. You do that if you want to reset the ECU not to reset the check engine light.
You're gonna have to take it to a Honda Dealer and have them reset it for you.
Old Apr 20, 2003
Macfay's Avatar
I thought by resetting the ECU, all sort of data in the ECU would be deleted...including the check engine light...
then the ECU will run all tests and set the correct values for 2 to 3 days...
Old Apr 21, 2003
solar's Avatar
solar is an unknown quantity at this point
The check engine light is on for a reason, its not on to just annoy you. Thers something wrong with your car so you need to take it into the shop.
Old Apr 21, 2003
02NCcivic's Avatar
02NCcivic is an unknown quantity at this point
just unplugging the battery doesn't reset the check engine light. my wife's car had the check engine light on and i had to put a new alternator in it and the battery was out for over a day and the light came back on right after starting it up. it's definitely something for the dealer.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
