Broken Endlink
Old Mar 28, 2003
Snort2001's Avatar
Snort2001 is an unknown quantity at this point
Broken Endlink
well..when i was intsalling my streetglowz, my friend noticed that my endlink broke on the driver side. here's a pic to show you what im talking about:
so yea...i've gotten advice to just leave it alone for now since i barely felt any difference while driving. anywayz, any advice from anyone?? i was thiking about replacing it with an aftermarket one or rsx sway bar.
Old Mar 28, 2003
solar's Avatar
solar is an unknown quantity at this point
I believe thats the link arm to the front sway bar, if it is you need to replace that very soon, it will effect your handling, especailly if you need to turn quickly to avoid a accident. It should be covered under warrenty.
Old Mar 28, 2003
CiViCrAcEr2003's Avatar
CiViCrAcEr2003 is an unknown quantity at this point
I hit a curb when it was really icey outside becasue my car slid into it and it broke the link that your talking about and a bunch of other stuff... the link is pretty cheap but the labor might cost you alittle bit more unless you do it yourself.
Old Mar 28, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
how on earth did you break that??
That looks like the rear endlink right?
You can buy replacement endlinks from honda for $180/pair, but it should be covered under warranty.
If i were you, i'd actually remove the sway bar for now because it's putting too much stress on the other endlink.. it might damage it you know?
damn, that's the first time i see a broken endlink with our stock anti-sway bar.
Old Mar 31, 2003
Snort2001's Avatar
ummm...i think it broke because of the weight of my trunk...it's pretty damn heavy. i think im just gonna drive around without a sway bar because i haven't felt any difference at all or else i woulda found the problem a long time ago. but if i do decide to replace it..i'll probably just get an aftermarket one..like progress or something
Old Mar 31, 2003
Ashock's Avatar
Ashock is an unknown quantity at this point
Man, and I've got rsx 19mm sway bar upgrade. I gotta check up on my endlinks. If they break under stock, dunno what's gonna happen later.
Old Mar 31, 2003
Snort2001's Avatar
well...first of all..do you have a 700lbs trunk??? cuz i do..and that's what caused it
Old Mar 31, 2003
flotsamm's Avatar
Daayum.. 700 pounds in the trunk? Thats crazy! The load capacity for our cars is something like 850 pounds I think. Maybe you need airbags hehe
Old Mar 31, 2003
Snort2001's Avatar
lol, i know i know...but isn't that capacity with like..stock suspension and everything?? shouldn't aftermarket springs such as ground control be able to help the vehicle handle more weight?
Crazygrlinak
Oct 8, 2015 05:06 PM
Dave Brabant
Sep 9, 2015 08:11 PM
amrhamed
Sep 1, 2015 06:27 PM
naokigoffi
Aug 30, 2015 06:19 PM
