Truck latch
Old Mar 24, 2003
AvrilLavigne45's Avatar
AvrilLavigne45 is an unknown quantity at this point
Exclamation Truck latch
I have been having so many problems with my truck latch just wanted to know if this is only a problem on 02's
Old Mar 24, 2003
DaveyD's Avatar
Mr. Negative
DaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the rough
Huh??? Describe your problem a little more.
Old Mar 24, 2003
SilverSport's Avatar
SilverSport is an unknown quantity at this point
do you mean TRUNK latch?
you gotta be more specific
Old Apr 1, 2003
usafstud's Avatar
If your talking about closing the trunk, its all in the way u close it. U have to give it a flick from the wrist, no a slam like other cars.
Old Apr 1, 2003
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Re: Truck latch
Just squirt some wd 40 into it. After winter, it seems like a little corosion built up in in on mine.
Old Apr 2, 2003
Connie's Avatar
Mine busted, but thats cause thye didn't install the right springs. But otherwise I have not had many problems other than it not locking every once and a while...
Old Apr 3, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
yeah i called honda about it and they said it is out of alignment, so i took it up there and it worked just fine.....and now its doing it again....so ill take it back later,
oh yeah it is a minor problem with most civics, although most are fixed before they are sold
Old Apr 5, 2003
CiViCrAcEr2003's Avatar
CiViCrAcEr2003 is an unknown quantity at this point
if your talking about the upside down 'U' piece that it actually latches to all you have to do is loosen the two bolts on it and match the guide lines on the 'U' piece up with those that are on the car... there are 3 lines right next to each other... stock should be on the middle one (you will know what I am talking about if you look close enough).. it takes a couple of minutes to do... no biggie.
Old Apr 5, 2003
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Mine is also busted. The little plastic piece in it is deformed. Hopefully they'll fix it Monday.
UltraHDGames
Jun 8, 2016 05:16 PM
Sep 27, 2015 11:33 AM
mightbuyacivic
General 8th & 9th Gen
Sep 26, 2015 09:43 PM
General DIY
Sep 25, 2015 08:02 PM
nixyfior
Sep 14, 2015 08:32 PM
