magnaflow rattle
Old Mar 24, 2003
Fletchman04's Avatar
Fletchman04 is on a distinguished road
Unhappy magnaflow rattle
When i am driving my car and i go around a somewhat sharp curve my exhuast pipe rattles. I know it has to be banging on something close to the header, but i can't figure out how to stop it from moving. If you've had a similiar problem, i would greatly appreicate your help. Thanks!
Old Mar 25, 2003
slicksivik's Avatar
mine rattles a little when its idle, kinda weird. i turn it on, and it rattles a little, dont hear it tho once i drive
Old Mar 28, 2003
vincenzobar's Avatar
THE WOP
vincenzobar is an unknown quantity at this point
it is hitting the sway bar atleast mine does. you need to raise it with adjustable hangers. they don't cost much. Mune rattle when i first start up and then if anyone is in my passanger seat. But i have a thermal R&D. so look closely at the thin bar behind the wheels.
Old Mar 29, 2003
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Re: magnaflow rattle
what model is your car? I know on my old 99 ex, the cat would rattle at idle. Prolly a honeycomb or two inside the car broke off. Id say bring it to honda for some insight.
Old Mar 30, 2003
2001civ's Avatar
2001civ is an unknown quantity at this point
Mine rattled twice. One was the clamp right in the middle hitting a metal plate under the car, and the second was the first highflow cat was broken and needed to be replaced, but the shop I ordered it fixed it no problem.
Old Mar 30, 2003
born2xLr8's Avatar
If it's hitting the underside of the car, try facing the clamps in a different direction....? Mine only rattles when i'm idle. The tip shakes against the rear bumper but it only happens when the car is at an angle, like on a hill. You might consider paying money to get it welded. That should fix all your problems.
mistahlorax13
21
Nov 18, 2015 12:47 PM
rovafa2002
Sep 28, 2015 06:57 PM
fvckbg
Sep 8, 2015 09:55 PM
dantheman42
Sep 4, 2015 01:10 PM
Yazan93
Jul 14, 2015 08:56 PM
