Water gurgling sound when.......
Old Feb 27, 2003
gipperkid's Avatar
gipperkid is an unknown quantity at this point
Hey guys I have noticed this alot in 02 LX since it has been cold. I have a five speed with about 8k on the motor. When I start my Civic in the mornings and rev the engine a little to ease out the garage I can hear a sound like water gurgling. It is only when I rev the engine very slightly, like to 1500 RPM's or so. It sounds like watery trans fluid being mixed, so-to-speak. I never really noticed it unitl it started getting cold. I can here really loud in the mornings. It sounds like it comes from behind the center A/C vents. I noticed this in my friends Civic also. It just bugs me. Do you guys have any input on this???? Look forward to your replies.
Tim
Old Feb 27, 2003
nytejade's Avatar
nytejade is an unknown quantity at this point
Wow, I thought that noise was in my head. I get it too. I've been getting it since I bought the car. When I accelerate slowly I can hear it gurgle. I hope we find out what it is. It's probably been discussed, but I have no idea how to search for a topic such as this.
Old Feb 27, 2003
Ant81's Avatar
Ant81 is an unknown quantity at this point
i have a 2002 Si and i get that also .. i didn't know what it was but then i checked my raidiator fluid filled it up and never got that sound again
Old Feb 27, 2003
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Thats so wierd, I just heard that noise for the first time this morning. I reved a few times and it gurgleg a few times then stoped. No clue!
Old Feb 27, 2003
cdmx's Avatar
Was the car moving? cause I can hear my gas making a swishing sound
Old Feb 27, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
all cars make weird noises during warm up...its aite[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Feb 27, 2003
RegulatorRacing's Avatar
RegulatorRacing is an unknown quantity at this point
maybe a lil indigestion in the morning? haha jk ... perfectly normal man
Old Feb 27, 2003
Friedrice's Avatar
Friedrice is an unknown quantity at this point
Maybe just coolant flowing though the heater core?
Old Feb 27, 2003
CivicGoh's Avatar
CivicGoh is an unknown quantity at this point
i get that gurgling, rattle sound also when i start up on first gear at low rpm, i took it to honda n they said they couldn find out what it was.
Old Feb 27, 2003
RiceBuRNeR's Avatar
Turbo Member
damn, I thought that was only my car doing that. That **** used to drive me nuts.
Old Feb 28, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
all wrong... when liquids get colder they take up less space, since the liquid is being cooler than standard temperatures... it is occupying less space... so the gurgling is because there is some air in parts of the cooling system... and when the car is warmed up the noise is gone... because the reverse is also true, liquids occupy more space when it is heated above standard temps...
enuff science for ya?
Old Feb 28, 2003
nytejade's Avatar
Quote
[hr]Originally posted by: WannaBFast
enuff science for ya?[hr]
I hear it all the time when my car is running at normal temperature.
How's that for science? : )
Old Feb 28, 2003
XxSoVeReiGNxX's Avatar
While I was at Honda a few times getting serviced, I tried to identify that noise to them. However it would not sound when I needed it to sound the most [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
They finally heard it in my last checkup, and they said it was ball bearings that needed to be lubed.
I didn't they knew what they were talking about. Sound's still there, but like you guys figured, only during warmup and low gear (accelerating from stop).
Old Mar 1, 2003
clownprince's Avatar
Ricerus Maximus
You have bubbles in your cooling system. Here's how to fix it. Start the car with the hood up and radiator cap off, you can also take off the resivoir cap if you wish. Let the car run for about 30 minutes with the heater on full blast, as hot as it can go, this will suck more coolant into the heater core and allow the air bubbles to escape. Keep refilling the radiator if the level drops any, this is just coolant taking the place of the air. After about 30 minutes it should be done and no more gurgling. (I ran into this problem after I did a coolant flush and forgot to have the heater on when refilling the radiator)
Old Mar 2, 2003
01civicboi's Avatar
01civicboi is an unknown quantity at this point
Quote
[hr]Originally posted by: clownprince
You have bubbles in your cooling system. Here's how to fix it. Start the car with the hood up and radiator cap off, you can also take off the resivoir cap if you wish. Let the car run for about 30 minutes with the heater on full blast, as hot as it can go, this will suck more coolant into the heater core and allow the air bubbles to escape. Keep refilling the radiator if the level drops any, this is just coolant taking the place of the air. After about 30 minutes it should be done and no more gurgling. (I ran into this problem after I did a coolant flush and forgot to have the heater on when refilling the radiator)[hr]
sounds great! looks like i'm gonna have to try that this week [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 2, 2003
neoretromax's Avatar
neoretromax is an unknown quantity at this point
Quote
good call, i remember this topic being brought up a long time ago. i still havent fixed it though
[IMG]i/expressions/laugh2.gif[/IMG] but now i can
Old May 1, 2003
pheaton's Avatar
A descendant of 2k1civic.com
Not a big problem. Happens to most all cars. It's only when you have the thermostat turned to the warm (red) position. Even if the fan is off it'll make the noise. If you turn it to the cool (blue) position then it will go away. Doesn't make it any less annoying though..
Old May 1, 2003
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
i have the exact same problem. i thought it was from the teeth of the gears i accidentally grinded slushing around.
Old May 2, 2003
DragonFly's Avatar
DragonFly is an unknown quantity at this point
yeah. i first heard the sound a few mo ago. i didnt know that it happened on most cars though. i had a 99 accord lx before this and it didnt make any sound like that. come to think of it, that car made a lot less sounds (clicks, rattles) than this car does... i dunno... kinda makes me wish i had gotten a used accord 5spd instead.
Old May 3, 2003
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
its normal....its the radiator fluid going through the system, and the heater core ect...
Hqly2001
22
Jul 12, 2015 06:44 PM
Jul 12, 2015 11:54 AM
Bounddyy
Jul 8, 2015 11:22 AM
fvckbg
Jul 7, 2015 07:08 PM
hayden55
Jul 2, 2015 06:12 PM
