reversing
Old Feb 26, 2003
JAG609's Avatar
JAG609 is an unknown quantity at this point
reversing
why the hell does my 02 ex sound like a damn battery powered car when im reversing??
Old Feb 26, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Because thats the noise the reverse gear makes in every single car with a manual transmission. It's totally normal.
Old Feb 27, 2003
FuKNGRuVN's Avatar
Civic Owns My SRT
FuKNGRuVN is an unknown quantity at this point
My SiG makes that noise too.... but it's an automatic.
:-o
Old Feb 27, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
its not a big deal, happens to all cars
Old Feb 28, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
sounds pretty cool though, no?
Kinda like a siren in a way...
Old Feb 28, 2003
solar's Avatar
solar is an unknown quantity at this point
Its the way the gears are cut, the reverse gear is a "straight" cut and very very strong while all the foward gears are "angularly" cut which makes them quiet but not as strong.
Old Mar 2, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
its just our beast of an engine!!!
i have always felt dumb backing up quickly because of that noise...oh well...
Old Mar 2, 2003
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
i dunno, i like the noise, lol. if i could i'd make every gear sound like that
Old Mar 3, 2003
Cisco88's Avatar
Cisco88 is an unknown quantity at this point
sounds like a R/C car.....
Old Mar 3, 2003
JohnnyLee's Avatar
7thgen guh chee
Quote
[hr]Originally posted by: Cisco88
sounds like a R/C car.....[hr]
Yea it does sound like one[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 4, 2003
txtadik's Avatar
txtadik is an unknown quantity at this point
sounds like a golf-cart to me [IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 4, 2003
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
its definately a 4 cylinder car trait, i've driven a bunch of 4 cyl's, and they all had that RC car sound. but i have never heard a V6 with that sound ( like my dad's maxima and minivan ). i dunno, i can care less about the sound, but....uhhh....how loud is it from the outside of the car?
Old Mar 7, 2003
2001CIVICLX's Avatar
2001CIVICLX is an unknown quantity at this point
Quote
[hr]Originally posted by: JAG609
why the hell does my 02 ex sound like a damn battery powered car when im reversing??[hr]
This will answer all your questions!!
http://auto.howstuffworks.com/question522.htm
"Manual transmissions use mostly helical gears, but reverse is a special situation that requires a different type of gear - a spur gear.
The gears that make up the forward gear ratios are all helical gears. The teeth on helical gears are cut at an angle to the face of the gear. When two teeth on a helical gear system engage, the contact starts at one end of the tooth and gradually spreads as the gears rotate, until the two teeth are in full engagement. This gradual engagement makes helical gears operate much more smoothly and quietly than spur gears. Also, because of the angle of the gear teeth, more teeth are in engagement at any one time, this spreads the load out more, and reduces stresses.
The only problem with helical gears is that it is hard to slide them in and out of engagement with each other. On a manual transmission the forward gears stay engaged with each other at all times, and collars that are controlled by the shift stick lock different gears to the output shaft (see How Manual Transmissions Work for details). The reverse gear on your manual transmission uses an idler gear (the large spur gear visible at the right side of the picture below), which has to slide into mesh with two other spur gears at the same time in order to reverse the direction of rotation.
Spur gears, which have straight teeth, slide into engagement much more easily than helical gears, so the three gears used for reverse are spur gears.
Each time a gear tooth engages on a spur gear, the teeth collide instead of gently sliding into contact as they do on helical gears. This impact makes a lot of noise and also increases the stresses on the gear teeth. When you hear a loud, whirring noise from your car in reverse, what you are hearing is the sound of the spur gear teeth clacking against one another! "
Old Mar 8, 2003
MIR's Avatar
MIR
~Your Favourite CiViC GiRL~
MIR is an unknown quantity at this point
Yes I found that noise to be extremely strange when i first got the car too..but its normal im assuming
Old Mar 8, 2003
neoretromax's Avatar
neoretromax is an unknown quantity at this point
Quote
rofl bwahahaha[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
they all sound like that
Old Mar 8, 2003
gorbachev's Avatar
gorbachev is an unknown quantity at this point
you can brag about the noise to people that its your turbo. hehehe
Old Mar 12, 2003
leleboy's Avatar
leleboy is an unknown quantity at this point
i don't know about a turbo, but have you ever raced someone in reverse? its hella fun!! and tuns heads really fast, just don't over rev. i don't know it the limiter will catch the reverse gear. yeah thats a good question... duz it??
Old Mar 17, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
A rev limiter does just that, it limits the revolutions, so it doens't matter what gear your in, if your going forward or backward. It'll do it in neutral, and in the air...
-Mark
nirvanaguy
25
Oct 26, 2017 07:26 PM
velozp
Dec 13, 2015 11:28 AM
ThatGuy913
Sep 28, 2015 05:35 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
BBrosario
Sep 17, 2015 07:51 PM
