Squeeking noise coming from THE transmission.
My brother complained to me that today whenever he pressed in the clutch there would be a squeeking sound (very much like the sound you hear when you lay down on a spring mattress) coming from the transmission. Not from anywhere inside the car but from the transmission itself. Any ideas of what this could be? If it still happens tomorow I figure he should give the dealership a call.
If you can pin it down to the transmission area (front RIGHT) then it's probably the bushing and bearing that moves the fork that goes into the clutch. That's what was wrong with mine and it took the dealer 4 times to find. It's a matter of repacking the bearings and greasing the bushings that are between the slave cylinder and the clutch itself. Takes about an hour to fix if that's what it is. Tell them to re-pack it with grease that can withstand colder temperatures (even if you don't need it). Get them packed with the stuff they use in the Odyssey sliding door bearings.... that's what mine are packed with and it's working much better, with no noise at all.
I had the same noise and I took my car to service and they change the clutch pump. This didn't fix the noise but I took my car again today for the same noise and they put some lubricant from the inside of the car. Maybe they put lubricant in the clutch pedal and it stopped doing the noise.
civicns
May 8, 2015 09:49 PM
