Signal Indicator Problem!
Old Jan 13, 2003
Chuck2Fast4u's Avatar
Chuck2Fast4u is an unknown quantity at this point
Singal Indicator Problem!
Hey everyone.. Listen to this : when my headlights are off and I "flick" the signals they work fine at a normal pace.... when my headlights are on the left one works fine but the Right one becomes Very slow..and whats even crazier is that the idle changes every time the light flashes...(very lil but you can hear it...)
Does n e one know whats going on witht hat?.. i checked all the fuses and the transponder/ relay..
I really wouldnt care but i have to go get the car inspected.. and you know how they are...
Old Jan 17, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
Definitely a case of bad grounds or you have an improper resistance load somewhere, have you did any mods/wiring or anything? Make sure all grounds are tight, and all bulbs are of the correct size and wattage, even check your back bulbs, they directly affect your front ones
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
steveneddy
May 19, 2015 02:39 PM
Fastfebur
Apr 22, 2015 01:37 PM
blackbullet
Dec 1, 2001 03:44 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
