Oil Nut Washer...
Old Oct 11, 2002
Macko's Avatar
Macko is an unknown quantity at this point
Oil Nut Washer...
I just realized that ever since my first oil change i didn't notic a friggin washer... i dun think my car had a washer in the first place or i would've realized taht i needed to replace the washer once i see it... this might be the answer to the mysterious oil spot in my garage...
Old Oct 11, 2002
solar's Avatar
solar is an unknown quantity at this point
You can buy them for 19¢ at H and A .com, when you did your first oil change the washer probably fell off into the oil drain pan when you pulled the plug out, it happened to me also.
Old Oct 11, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
I just got off the phone (as in 5 minutes ago) with the Honda dealer. You can also use the rubber washers that every other car uses. And those are reusable. The guy at the dealer says that it will work the same as the aluminum crush washer.
EDIT... I just changed mine. The washer is re-usable, it's just a plain old aluminium washer. Just make sure you get one, and as long as you don't lose it youi should be good. I got lucky, mine stuck to the drain plug, but I bought an extra one just incase I lost it.
Old Oct 12, 2002
1955's Avatar
i will be dog gone,there is a washer alright,sometime it stuck on the metal after the drain plug is out when u tried to avoid the hot /warm oil,u can use the paper from a box of milk to make a washer or gasket of anykind.i found my washer at the bottom of the used oil and i am savin it for the next oil change
SimpleUser
Apr 24, 2021 02:54 AM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
brags
46
Jan 7, 2016 09:39 PM
17
Jul 23, 2015 11:48 PM
califcamper
Jul 21, 2015 10:34 PM
