Engine Rattle during acceleration
Old Sep 26, 2002
hondah1's Avatar
hondah1 is an unknown quantity at this point
Hey, I have a 02 LX Manual and for some reason during acceleration my engine rattles. Normally it begins at around 2500 RPM and stops at
about 3300, I think. (or it could be that the engine becomes too loud to hear the rattle at that speed) Anyway, this is my first
manual, and I'm not sure if this is a normal sound, but it doesn't sound too healthy. Is this normal? It stops as soon as I release or
lighten up on the gas pedal.
Also, does anyone else have discolored plastic surrounding their instrument panel? Kinda looks like a grey/black color in some spots and
black in others, like it's supposed to be.
Thanks
Old Sep 27, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
The rattle might be a loose heat shield on the header...see if you can tighten up all the bolts.
Old Sep 28, 2002
hondah1's Avatar
Thanks - I'm gonna check that out! This is a weird description, but the closest thing I can compare the
noise with is maybe a tiny piece of metal inside a tin can rolling around. Not too loud, but annoying.
I read in the owners manual, says that use of any gas with an octane level below 86 can cause
a "metallic rapping" noise - I use regular unleaded 87 octane, maybe I should try a different gas
station for a while or something? Thanks for the advice, gonna give it a try!
Later
Old Sep 28, 2002
PESTLNC's Avatar
Wow, you just decribed pinging quite well. Now it sounds to me like you got a bad batch of gas. Since it's already pinging, go fill up at a Mobil or Amoco station with premium and add a bottle of Chevron Techron to clean out the fuel system...that should stop the problem. If it doesn't, you may have a more serious problem.
Old Oct 2, 2002
alc's Avatar
alc
alc is an unknown quantity at this point
well i have the same prob, but i would describe it as a whinning sound not rattle ( like some kind of flap opening then air flapping it around or something or like having a bad catalitic converter), especially when i drive through an alley or in the garage with both windows
open i hear this whinning sound when i rev id say fron 2000 to 3500 rpm, i should take it to the dealer and have them look at it, i wont have any problem replicating
it. it happens all the time, i just hate waiting at the dealer, if you guys have any info please share = ) im sure its something minor... my car runs awesome.
Old Nov 11, 2002
civico's Avatar
civico is an unknown quantity at this point
I had that problem... it isan exhaust problem. I don't have the repair papers in front of me but I'll look up the part that was replaced and post it.
Old Nov 11, 2002
hondah1's Avatar
civico - that would be great! I made an appointment at the Honda dealership, and the tech rode with me and asked me to duplicate the
problem. He couldn't hear it, selective hearing I guess. That punk bish. I heard it the whole time.
Thank you for your help!!!
Old Nov 11, 2002
PESTLNC's Avatar
Some quotes from Honda:
Quote
[hr]On ’01 Civics, the engine mounts can cause an engine vibration or an underhood rattling that's worse with the transmission in Reverse or Drive. To isolate this noise, use a Steelman ChassisEAR to listen to the engine mounts, or install known-good front and left-side engine mounts.[hr]
Old Nov 11, 2002
artychris's Avatar
artychris is an unknown quantity at this point
The solution will cost you $100. I have a 2001 EX Coupe MT and I noticed a rattling noise in excess of 3000rpm. Once I installed a Neuspeed Upper Strut Tower Bar, it tied the chassis together which holds the opposite engine mounts and eliminated rattle. I can rev to redline and it feels as if the engine is more stable at high revs.
Old Nov 12, 2002
PESTLNC's Avatar
That may fix the rattle, but may not fix the exisiting problem. I have also noticed a rattle, but am unsure what it is...my car will be going in for no less than 8 warranty repairs shortly. I'll also ask them to check out the rattle as well as other things. Surpressing the signs of a problem is one thing...fixing them is another!
usajags84
15
Aug 19, 2015 03:12 AM
cruisers10
May 12, 2015 10:46 PM
Marcus2thextrem
May 10, 2015 03:08 PM
BootyDo
May 8, 2015 05:36 PM
dooner24
Apr 14, 2015 07:51 PM
