Rattling while driving
Old Jul 17, 2002
Ger's Avatar
Ger
Ger is an unknown quantity at this point
I have a 2002 CIvic EX and noticed that when i drive i get a rattling that sounds like plastic.. i dunno its hard to describe... It sounds like the car is splitting in half like its cheap or something... is the DIY trunk rattle something that will correct this? does anyone else have this problem and if so, how did you get rid of it?
Old Jul 17, 2002
solar's Avatar
solar is an unknown quantity at this point
Well first off you'll probably get a post from someone to tell you to do a search,........... you'll see.
Anyway if its coming from the rear deck panel, then its a common problem with the 7th Gen, its most likely the "3rd brake light". Mine did this when I bought mine back in November, (I have a 02 EX) I took it to the dealer and they put some kind of tape in it. It worked for about 2 days and the rattle came back. I ended up pulling the whole rear deck out, removing the tape the dealer put in and wrapping the "3rd brake light" on the outside with commercail double sided foam tape,(you can get the stuff from Office Depot, or Staples). No rattles since, and its been about 3 months.
Old Jul 18, 2002
lemoncivic's Avatar
lemoncivic is an unknown quantity at this point
Quote
[hr]... It sounds like the car is splitting in half like its cheap or something... [hr]
I think that you answered your own question
Old Jul 18, 2002
solar's Avatar
Quote
[hr]Originally posted by: lemoncivic
Quote
I think that you answered your own question[hr]
Lemon Civic give up your day job and become a comedian, your really funny.
Old Jul 18, 2002
lemoncivic's Avatar
I try to have a sense of humor about this 7th gen civic but, most of the time it really pisses me off. But, it still gets me to where I need to go. And, in the end - good or bad - it's just a car. As I write this my car is in for new struts. F'in hysterical!
Old Jul 23, 2002
02CivicEX's Avatar
02CivicEX is an unknown quantity at this point
My roof inside my car rattles (above my head, and at the back), the back sounds like plastic rattling together, have somone ride in the backseat so they can see if that helps you..
i still have to take mine in to the dealer, i just have to find time.
Old Jul 23, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
yeah i had this problem when i first got the civic in 2001. believe it or not most of the rattles have settled, with exception to the rear deck which is the only one i need to fix.
also the trunk will rattle around the braces behind the license plate, the factory does not put any caulk/silicone there. just open the trunk and look directly behind the license plate on the inside, you'll see two medium sized funky shaped holes. press on the metal and you'll see that it will flex easily. just put a bead of silicone in the crack there and it'll be good.
Xuhme
21
Aug 7, 2023 03:40 PM
usajags84
15
Aug 19, 2015 03:12 AM
BootyDo
May 8, 2015 05:36 PM
smmahan
Apr 15, 2015 08:17 PM
blouisgod
Dec 28, 2001 09:30 PM
