shaking at 75mph+
Old Jun 4, 2002
bake's Avatar
bake is an unknown quantity at this point
shaking at 75mph+
i noticed the other day when i got on the interstate that when i got up to around 70 75 mph the car started to shake. Would this be because of the rims being changed?
Old Jun 4, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
My car is stock, it shakes too at 75+mph. I think it's just air resistancy and other aerodynamics related things.... just a guess
Old Jun 4, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
Check to make sure your tires are all the same & air pressure is set right. I had this exact same problem with my old car; i had 4 mismatched tires.
Old Jun 5, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
check this thread llink
Old Jun 5, 2002
mattskav's Avatar
mattskav is an unknown quantity at this point
things to check:
wheel balance (definatley the most likely cause here)
blown struts (have someone drive over bumps while your in a car behind)
broken engine mounts (you'd hear a clunking too)
Old Jun 5, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Yeah, Ronin really educated me on this point...I have Motegi MR7's and it took me like 4 times of running back to the tire place to get my tires rebalanced...the conventional way to do it is putting the weights on the outside of the rim...what you need is high speed balancing where they put the weights on the inside of the wheel...once I had this done, no more shaking even @ 80 mph and above...
2Hottie
Old Jun 8, 2002
Assasin's Avatar
Assasin is an unknown quantity at this point
i got skunk2 coilovers on my sedan and i be going like 100+ on the freeway and my car dont really shake much only if i hit a wicked bump my wheels fly up in the air its crazy lol
Old Jun 8, 2002
BlackSI's Avatar
BlackSI is an unknown quantity at this point
If you havent already checked, i'd make sure all the lug nuts are torqed enough/and or correctly
Old Jun 11, 2002
Strider's Avatar
Strider is an unknown quantity at this point
Try putting in a higher grade gas, if you are not already. My car started to shake around 75+, but it is fine now... then again I haven't really been pushing it too too hard since then.
Old Jun 11, 2002
TwilightX's Avatar
TwilightX is an unknown quantity at this point
Mine does it too, and from what I heard, it does relate to the tire pressure and balancing...I'd check that out first...
T-X
mgrantaz
General
May 2, 2022 05:40 PM
Solo Flow
Oct 4, 2015 07:52 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
Mannimarco
Sep 7, 2015 10:01 PM
rainman15
Sep 6, 2015 11:10 AM
