Awful Squealing
Rep Power: 0 Awful Squealing
2002 Honda Civic EX - L4 - 1.7L 1700cc
Horrible squealing when started and engine isn't warmed up. Gets worse when air is turned on, AC or Heat, and also when I slow down to turn. Will go away when I accelerate or even revving the engine while in nuetral.
Sometimes I can just turn the car on and let it idle and it wont squeal until I put it in Reverse or Drive. But other times it squeals reguardless. It's also began lasting longer than it originally did
Last edited by MmJr0120; 10-15-2018 at 07:25 AM. Reason: Needed to add information
Re: Awful Squealing
Belt(s) not tight enough, and check if the alternator bolts were left loose
jimmyangst
06-07-2017 10:09 PM
JWoolf
05-10-2010 02:43 PM
