Civic DX 2004 Engine broke
Rep Power: 0 Civic DX 2004 Engine broke
Hi, i broke the engine of my honda civic 2004 Dx its standard i would like to know witch engine could i use ? i know its not vtect its a 1.7 right ? can any one point me at the right direction ?
Re: Civic DX 2004 Engine broke
You'll find the engine code is stamped on the front of the block near the bellhousing.
Probably D17A1.
Probably D17A1.
There is no reason not to use a vtec engine as a base for swap. You never need to hookup the vtec selenoid for it run. At some point in the future if you add a vtec controller you will feel increase in power from 4K rpm up but it’s not going to knock your coffee over or anything.
