Fluid leak behind crank pulley. Not motor oil.
Old Jun 19, 2018
Mike48's Avatar
Mike48 is an unknown quantity at this point
Hey guys. Any help is appreciated.
2003 civic 1.7L auto.
A leak has started behind my crank pulley. I'm 90% sure it's not motor oil. It's clear and clean and it only leaks when I shut the car off. It looks like brake fluid but I don't see how thats possible. It is definitely a oil based product leaking. It's not rad fluid or AC condensation water.
thanks again
Behind the crank pulley is a small hole that has a small rubber flap covering it. That's where the fluid is coming from. Is that the timing belt cover?
Old Jun 19, 2018
Wankenstein's Avatar
Re: Fluid leak behind crank pulley. Not motor oil.
Either oil leaking from crank seal, oil leaking down from valve cover or coolant from water pump or head gasket. Losing any coolant in radiator?
Old Jun 19, 2018
Colin42's Avatar
pictures
Old Jun 19, 2018
Mike48's Avatar
Thanks for your help man. This is a strange one. its not rad fluid or motor oil. I think I'm loosing brake fluid. Is there anyway that is possible. I don't see and leaks from the lines, brake fluid tank, or the master cylinder. I'll try and post some pictures tonight.
When i shut the car off about 5-10 seconds later it dribbles out of that little hole. It leaks for about 10-20 seconds then stops.
Old Jun 19, 2018
BrotatoChip's Avatar
Super Moderator
Dribbles out the little hole? Are you talking about the weep hole on the water pump?
Old Jun 19, 2018
Mike48's Avatar
Originally Posted by Colin42
pictures
i will post some tonight. Thanks.
Old Jun 19, 2018
Mike48's Avatar
This is the front (outside) of a lower timing belt cover. The little hole I'm talking about is magnified I'm guessing this hole is to allow fluid to leave from behind this cover.
Old Jun 19, 2018
Not sure on a 7th gen but on a 6th gen the brake master cylinder feeds into brake lines that run along the firewall and feeds off the proportional control valve. If a 7th gen is the same then it shouldn't leak brake fluid to the lower timing cover.
Tracecross30
Transmission
Aug 21, 2019 04:28 PM
baseballetc14
Oct 21, 2012 12:40 PM
Awad-Honda
Apr 30, 2011 09:35 PM
scott37300
17
Feb 9, 2011 09:28 PM
boosted2cam
Transmission
Jan 20, 2010 08:44 PM
