RPM Issues
Old Jun 11, 2018
space46's Avatar
space46 is an unknown quantity at this point
Angry RPM Issues
Ok here is my story. I changed out my motor on my 2002 Honda Civic from a vehicle which had a automatic transmission . My vehicle was a straight shift. Motor runs great however I cannot go a move 4,000 rpm without the motor acting like it has a governor on it. There was one area on the motor that my old motor did not have. Because this switch or whatever it is is not hooked up I now have a engine light and the code Im getting has something to due with oil pressure on the cam. I was told there is a way to trick the computer by placing a resistor into the wiring so the computer does not sense the low oil reading. I know where I need to put the resistor but not sure what size I need to use. Any help would be greatly appreciated.
Old Jun 11, 2018
Re: RPM Issues
You put a D17A1 into a car that needed a D17A2, now the PCM hates you because it can't find VTEC?
Old Jun 11, 2018
space46's Avatar
Re: RPM Issues
So do you know if there is a way to place a resistor into the path to tell the computer what it wants?
Old Jun 11, 2018
Re: RPM Issues
You can't use a resistor to fool it. That's not what the PCM is looking for.
Old Jun 11, 2018
space46's Avatar
Re: RPM Issues
So any idea what I can do. i have been driving the vehicle for nearly 2 years like this but would love to make the check engine light go off.
Old Jun 11, 2018
Re: RPM Issues
Install the correct engine?
Install a correct VTEC cylinder head on this wrong engine?
I wonder....If I had a wiring diagram, and if I knew what the computer controls, and I knew exactly what the computer is looking for when it tries to activate the VTEC system, I wonder I could build a circuit that would fool it-- using a simple relay.
Old Jun 12, 2018
space46's Avatar
Re: RPM Issues
Makes sense. I will keep trying "when there is a will there is a way".
Old Jun 12, 2018
Re: RPM Issues
or install a ECU from any other car that is not an EX.
keys will need to be reflashed.
Murphys Law
General
May 30, 2019 10:04 AM
camodad.17
Oct 24, 2017 07:15 PM
MrCivic1995
Feb 6, 2006 03:04 PM
Island2K2
Dec 30, 2003 04:17 PM
tiredwolf
May 27, 2003 04:40 PM
