2005 lx getting too much fuel?
Throwing code for bad o 2 sensor, replaced it same thing... When I have it throttle it bogs down like carzy... Have to floor it to idle but if I just give it a little throttle it will rev up past 3k but that's it... Changed plugs, coils same thing. Plugs have lots of gas on them computer says all 4 cylnders missfire. Need help where do I start??? Will post video of what it's doing tomorrow. If I let it idle it idles VERY RUFF. Any help is verry appreciated btw car is un drivable can barely keep it above 3k. Thanks.
Re: 2005 lx getting too much fuel?
Too much gas... 05 Honda civic
Computer says misfire on All 4 cylinders I think it's getting too much gas there's a bunch of gas in the spark plugs.. just replaced em and the coils. Idles like **** and bogs when I rev it.. won't rev past 4k undrivable. Replaced plugs coils and 02 sensor. Throwing code for O2 sensor. Pls help. Where do I start. Bad cat. Ecm. Fuel pressure regulator... Idk
Clicking sound usually comes from relays behind the glove box and they usually start clicking when ground connections ion the engine /frame have loosened up or partially broken.
I would suggest starting by unbolting the grounds in the thermostat area, cleaning them really good and reinstalling.
Not just talking the body to engine connections, but the multipoint wireharness grounds to the engine.
where do I start???
devkay
Apr 15, 2014 04:46 AM
AllThrottle4U
Aug 15, 2011 06:31 PM
qzany89
Feb 10, 2011 09:45 AM
DX5spd
16
Jul 26, 2010 05:21 PM
