Help code p0134
Old Mar 23, 2018
Mojo20032004's Avatar
Mojo20032004 is an unknown quantity at this point
Help code p0134
Hey all, looking for some help. I consider myself a pretty good diy when it comes to cars Have gone from replacing turbos to transmission swap and engine swaps, but this is something irritating .
Bought a brand new afr sensor part 36531-PLR-003 or 234-9017(Denso of course, nothing else, also 234-9017 stamped on side of sensor) sensor and still getting the damn code. Comes up after about 2mins of idling or driving. Check for voltage with car idling and with ignition on and we are good. I beleive it was 14.2 idling and 12.6 with ignition on. Car drives smooth, no misfires or hiccups or black soot. If it wasn't for the light on the dash, no one would notice or hear a issue
If I swap out to the original sensor that was in there at first, I would get a p0135 code after about 20 seconds Heater failure on sensor, but once I throw in a new one, it throws a p0134 code..
From my understanding there is 4 wires.1 hot(white)1 ground(green) and 2 signal wires(red/ylw and red).i have power in 2 of them. Voltage from battery in the white one, but green one turns on/off. From my research I beleive that's controlled by a relay that the pcm tells it to turn on/off depending on needs. Is it possible the relay bad ?
Im leaning towards either getting the pcm reflashed by honda (original owner car) so this was never done, or try another 250 doller afr sensor.
Old Mar 23, 2018
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
Re: Help code p0134
Where did you buy the sensor from?
I had this problem but my code was P0134 for no activity.
I got two different sensors from ebay and those did not work. Then I got one from Amazon and that one looked legit, sealed and all the packaging.
One of the replacement sensors I got also had the 234-9017 stamped on the side but the original did not, the original also had other numbers so I suspect the sensors from ebay where fake...
Old Mar 23, 2018
Re: Help code p0134
Yes the sensor was bought on eBay, did not come in a sensor box, but came in a Honda bag sealed with a Honda part number.but now that I think about it, when I processed it over PayPal, it shows Chinese letters vs normal English. So it's possible I got a fake as well. And my code is also p0134 for no activity.
Old Mar 23, 2018
GusBuz's Avatar
Re: Help code p0134
As i suspected, get a refund and just buy one from amazon it currently is going for $123.
It should come in a box with a lil tube of anti-seize
Old Mar 23, 2018
Re: Help code p0134
Yea I see the sensor. 123.00. Doesn't say what's included but does have a picture of the sensor with right part number
Old Mar 23, 2018
Re: Help code p0134
I see it. I will give it a shot. Hopefully this one works.
Old Apr 3, 2018
Re: Help code p0134
Replaced with oem sensor, none of that ebay crap.. Light turned off and been cel free for 400 miles
Camden
Oct 9, 2011 01:41 PM
phaj
Jul 6, 2010 07:29 PM
papersun1
Mar 19, 2010 01:19 PM
hybridhaver2005
Feb 3, 2009 08:21 PM
hybridhaver2005
Feb 3, 2009 04:57 PM
