2002 To 2004 D17A1 Swap Issues
Old Mar 3, 2018
BrandanEM2's Avatar
BrandanEM2 is an unknown quantity at this point
I just did a swap on my civic with the same motor but just from the 2004 civic. Swapped everything over. EGR, ignition switch and wire harnesses. Car is acting really weird. It's running terribly bad and it keeps sputtering and it's hard to start. It will start up when it's cold but when it's hot it sputters and stuff. Connected a OB2 Scan tool to see that it has a link error. Before I did the swap my civic has always been stuck in limp mode so we just reverted everything back to stock. Is it possible that the dash harness has something to do with this? And why is my civic running so bad? Before the swap I started up the same motor in the parts car and it ran fine but now it's questionable. Any ideas? Desperate for help. Btw it's manual and I swapped over the 2004 ecu.
Old Mar 3, 2018
Slumpertcivic's Avatar
Re: 2002 To 2004 D17A1 Swap Issues
Oh holy snap dude..
So you also moved over the O2 sensors? 2002 and 2004 use different types.
Old Mar 3, 2018
Still got the original engine? See if the alternator mounting bolts were loose.
Grounds, grounds, grounds
Old Mar 3, 2018
BrandanEM2's Avatar
I made sure everything was right on the alternator
I made sure the harness ground and the engine ground is connected
Old Mar 3, 2018
BrandanEM2's Avatar
Originally Posted by Slumpertcivic
Oh holy snap dude..
Dude I know. It's terrible and yes I have swapped them over.
Old Mar 3, 2018
9 times out of 10 when a PCM no longer communicates with a scanner, warning lights may be on, people say the relays click away behind the glovebox and power is severely restricted, it's found that the alternator mounting hardware had been loose at some point......... and the resulting 'runaway charging voltage' burned out the PCM.
Poor/bad ground cables for the drivetrain can cause the same issue
You've got a lot of swaparoo going on, I thought it was worth mentioning just because of your description.
There are some wiring differences between early and late, and vtec/non-vtec..both in the engine harness and the dash harnesses: AF sensor heater relay, and rear O2 sensor plug location immediately comes to mind...probably also some differences in ECM pinouts.
2001-03 used a regular O2 sensor in the primary location, 2004-05 use AF sensor in the primary location. They look about the same and do roughly the same job but electrically they are very different, their respective ECMs are very different, the sensors cannot be swapped as the ECMs have no idea what to do with the incorrect inputs..
I'd suggest you get a good set of wiring diagrams and research.
Old Mar 3, 2018
BrandanEM2's Avatar
Yes there is a clicking on the relays. They engines are both D17A1s the only thing I'm thinking of now is the dash harness and the alternator as you told me. But for sure the relays are clicking.
Old Mar 3, 2018
The harnesses probably won't have anything to do with an ungrounded alternator and PCM burnout.
Something else people notice is the gauges are affected when the PCM loses its mind. 3 of the gauges are run by data coming from the PCM on a communication network, and once that data is corrupted the gauge cluster processor kinda goes stupid (coincides with loss of scanner communication).
Since we don't know how/when or if this current ECM is permanently damaged, I'm going to urge you to recheck the mounting bolts for the alternator, its mounting bracket, and engine/trans/chassis/battery grounds.
Once the PCM has lost its ability to communicate (data) with a scanner, most won't come back from that damage.
If you don't find and correct the root cause, it's doomed to repeat the failures and that gets expensive in a hurry
RFoxx
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 29, 2020 10:44 PM
sponiebr
Jan 5, 2018 05:29 PM
Metalzone
16
Oct 16, 2014 07:18 PM
bhut2180
Apr 13, 2014 09:26 PM
DC
Sep 16, 2002 05:25 PM
