Need Help Fixing A 04 Honda Civic Transmission
Old Mar 2, 2018
Hollow Gram's Avatar
Hollow Gram is an unknown quantity at this point
I NEED HELP
I BOUGHT A 04 HONDA CIVIC EX WITH 97k MILES AND THE ENGINE BLEW A ROD THROUGH THE OILPAN
DO YOU THINK THE TRANNY DONE TOO ? ALL THE OIL LEAKED OUT WHEN IT BLEW AND OFCOURSE IT WONT START
I PLAN ON BUYING AN JDM D17 AND SWAPPING TO FIX BUT IF I DO HAVE TO FIX TRANSMISSION AS WELL?
IS IT POSSIBLE TO REBUILD EASILY MYSELF OR WHATS THE BEST OPTION LOOKING FOR CHEAPIEST
IF I DO HAVE TO REPLACE WHERE CANI GET A MANUAL 04 TRANSMISSION CANT FIND ANY ONLINE AT ALL?
PLEASE HELP I PLAN ON BUYING A HANES AND GETTING A KNOWLEDGEABLE FRIEND AND DOING IT OURSELVES ANY LIGHT WILL BE MUCH APPRECIATED OR HELP OR ADVICE
Old Mar 3, 2018
Slumpertcivic's Avatar
Re: Need Help Fixing A 04 Honda Civic Transmission
Engine and transmission have their own oil systems so your tranmisssion won’t be any worse.
Old Mar 4, 2018
mac25's Avatar
Dr Krieger of Modification
The transmission should be fine.
If you can
-jack it up
-put it in first
-rotate the wheels by hand
-repeat for each gear.
-if every gear rotates and there are no odd sounds, then you should be fine.
-make sure that the crank can rotate by pulling the oil pan so the brocken rod doesn't bind somehow.
- If there is a transmission problem, pull the transmission and get it rebuilt; that will save money and insure your transmission is new.
Nayzco91
Exterior
Apr 17, 2017 07:14 PM
stevencg
Dec 10, 2011 08:12 PM
fsinadin
Oct 22, 2011 12:25 AM
civic02ex
Aug 17, 2003 12:55 AM
wonderz
Detailing
May 24, 2002 12:38 AM
