Need Noob Help Replacing A d17a1
Old Jan 1, 2018
Hollow Gram's Avatar
Hollow Gram is an unknown quantity at this point
PROBLEM:I bought a 2004 civic manual in hopes of replacing engine in it to get it up and running but im not really finding alot of good information
I KNOW I SHOULD HAVE RESEARCHED FURTHER BEFORE BUYING BUT IT IS WHAT IT IS I JUST WANT GET CAR UP AND RUNNING
The Car Is Perfect Other Than The Engine Knocking And Blowing a Rod Through The Oil Pan
I have some minor mechanic knowledge of how fix minor engine problems but i have no type of experience taking an engine out and putting a new one in . I need some knowledge on everything i would need to replace engine with another working engine (Either a extensive how to or some kind of guide )
ALSO WHATS BEST WAYS FIND AN D17A1 ENGINE CHEAPEST AND BEST CONDITION
PLEASE IF ANYONE HAS ANY KIND OF KNOWLEDGE ON THIS MATTER OR EXPERIENCE FEEL FREE TO SHED SOME LIGHT BECAUSE I HAVE NO CLUE WHERE TO START OTHER THAN GETTING SOME OF THE TOOLS NEEDED
Old Jan 1, 2018
Re: Need Noob Help Replacing A d17a1
engine comes out from the top. (easiest way) so you need crane
Old Jan 1, 2018
Slumpertcivic's Avatar
Not sure what kind of information your looking for, Get the Haynes manual and turn to the chapter on engine removal..
JDM places generally advertise they are under 60,000 miles, junkyards will vary from 1-500,000 usually if they post a mileage it’s honest as most states require all parts to be trackable to the day/vehicle/ seller the yard got it from.
Taking the time to bag and tag and even diagram where each bolt you take off will do wonders for putting it all back together correctly.
Old Jan 2, 2018
Colin42's Avatar
take lots of pictures, use pieces of masking tape and a sharpie to mark electrical connectors
grab a buddy that has experience
Old Jan 2, 2018
Wankenstein's Avatar
One potential issue on 7th gens that I don't think was a problem on 6th's gen is the location of a/c pipe across/near the top of the valve cover.
Old Jan 2, 2018
Colin42's Avatar
unbolting the compressor from the engine and undoing the line brackets should give you enough room
Old Jan 2, 2018
Old Jan 2, 2018
he is just swapping another D-series into a D-series car. Only item is the usual VTEC or no VTEC and the non-EX header/exhaust and the O2 sensors. All famous stuff that he could easily find with a quick search in the forums. Otherwise, remove and drop new in.
Old Jan 8, 2018
5.0Thunder's Avatar
5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough
It's usually recommended to replace a few commonly failed items on the newer engine before dropping in, since it'll be easy when the engine is out. This includes timing belt/tensioner, thermostat, spark plugs obviously, head gasket, and maybe a few other items I'm forgetting.
Old Jan 8, 2018
^ water pump, since it goes at same work as the timing belt anyway.
the crankshaft balancer also?
bhut2180
Apr 13, 2014 09:26 PM
FRCornelis
26
Feb 26, 2011 01:29 AM
fastmods22
Buy, Sell, & Trade - Archive
Sep 5, 2007 08:41 PM
Karumba
Engine Swaps
Oct 27, 2004 02:16 AM
Shadow
Jun 6, 2003 06:53 AM
