Sandpaper-Like Sound from Driveshaft Area
Old Sep 28, 2016
honda.lioness's Avatar
honda.lioness is a jewel in the roughhonda.lioness is a jewel in the roughhonda.lioness is a jewel in the rough
1.
It sounds like fine sandpaper wrapped around a rotating metal shaft. It does not happen at all speeds. I think it's present more often when the outside temperature is low. It sounds like it's coming from the lower front passenger side, but I could be wrong. The 2003 Civic has 176k miles on it. Could the grease in the driveshaft boots have dried out?
2.
I inspected all four front driveshaft boots the other day. No leaks. No clunking on turns or anything, either. I took apart the front brakes, lubed the four pins and brake pad shims per the shop manual with synthetic grease and moly, and inspected carefully. No sign that anything is amiss.
3.
I have the shop manual directions for replacing the driveshafts (a.k.a. halfshafts); a honda-tech.com DIY site on same; and am ready to buy a few tools to do it. Any suggestions for where to buy the halfshafts? Ebay has them. I think autozone does too. Is it a good pre-emptive practice to replace the halfshafts after this many years and miles?
Old Sep 28, 2016
Re: Sandpaper-Like Sound from Driveshaft Area
.....Brake rotor dust shield contacting rotor?
Old Sep 28, 2016
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Bad wheel bearings? They make more of a growl sound though.
Old Sep 28, 2016
Wheel bearings are indeed also on my mind. I suppose I might have to let the problem "develop" more.
ezone, I did not see anything bent up around the brakes, but I could have missed it. Yes, I am wondering about brake lining dust. I use OEM pads and shoes always, having replaced both in the last year. When I cleaned all four wheels' brake areas the other day, things did seem less gritty-sounding. I got a lot of brake lining dust out of the rear brakes in particular.
Old Oct 2, 2016
I have narrowed the sandpaper-like sound as follows:
-- Happens when in 2nd, 3rd, 4th, or 5th gear, with foot off the gas pedal, above 20 mph. (My Civic has a manual transmission.)
-- It also happens in 2nd, 3rd, 4th and 5th gear when the cruise control is on and the car is going downhill (requiring less throttle, so it's like one is taking one's foot off the gas pedal).
-- Does not happen in neutral.
-- Goes away the instant I push the clutch pedal.
-- Is not a function of pushing the brake pedal or releasing the brake pedal.
Last edited by honda.lioness; Oct 3, 2016 at 04:42 PM. Reason: Added 5th gear and cruise control observations.
Old Oct 2, 2016
Exhaust heat shields buzz/rattle?
A next step might be to raise the wheels off the ground (safely) and see if it still makes noise in 2,3,4 gears, then use ears and a stethoscope to narrow down the location of the noise.
Old Oct 3, 2016
ezone, thank you for suggesting raising the front wheels and having someone press the gas pedal while I stay away from moving parts and try to narrow the sound. I am going to try to get a bud to help me with this sometime this month. First place I will try to examine is the gearbox.
I just edited my prior post to add a bit more info.
Old Oct 3, 2016
The updated description makes me think it's inside the transmission also. Might be a bearing issue allowing unwanted movement of something inside the trans.
Any leaks from the trans, or low fluid level?
over45
Mar 21, 2016 01:05 PM
MamaBear2015
Exterior
Mar 3, 2016 09:56 PM
Civic_k20a
Feb 22, 2016 01:19 AM
big20ugly
Nov 11, 2001 08:30 PM
