window won't t roll up!!
Old Jul 29, 2016
Cj LucidLife's Avatar
Cj LucidLife is an unknown quantity at this point
I have an 04 honda civic lx. One day I rolled the driver side window down, and it just didn't roll up again. I'm not sure what the problem is. All the other windows are fine. I took a 9v battery and hooked it up to the wires that are connected to the switch , but it didn't do anything. It rains here a lot in fl, and my car has been getting soaked! How can I get my window up temporarily while I figure this problem out?
Old Jul 29, 2016
Re: window won't t roll up!!
A tiny 9v battery probably doesn't have enough juice to roll up a window.
Remove door panel, find wires for the window motor, use a car battery and/or jumper wires to connect directly to the window motor?
Old Jul 30, 2016
I read online that a 9v should do the trick. I'll try that and get back to let you know. Speaker wire should be ok right?
I took speaker wire, and connected it to the 9v, and then took the other end, connected it to the wires that are connected to the window switch. I'll take pics and post them up here.
Old Aug 2, 2016
Anyone please help me!? It rained here and now my car smells like mildew! I don't want to take it to a mechanic, and rather do this myself. I just want the window rolled up for now, until I can have the time to fix it
Old Aug 2, 2016
CraigW's Avatar
You are going to need to feed voltage from the battery..... there is no way a tiny 9V will work.
Old Aug 2, 2016
I can just wrap speaker wire around it the battery terminals, and stick the other end in the the plug right?
I read that I would have to splice a few wires. That makes me a bit nervous, and rather not have to do something like that
Old Aug 2, 2016
So I bought a 12 v battery, and connected speaker wire to it. The only thing I could do is rollup and down the right rear window.
Old Aug 2, 2016
It's real apparent you didn't follow this instruction:
You sure 'bout that?
You need to get inside the door to see what happened to it anyway, right?
And/or test for power and ground at the window motor connector.
If it broke the regulator or the motor is bad, applying power to the motor isn't going to accomplish much.
Most people with a modicum of faculties would have kept a trash bag or something similar taped over the big open hole to keep rain out.
Now you might be needing to remove the interior to dry out the carpet and dry the padding under the carpet....and try to kill the mildew before it gets worse. BUT no real hurry to get this done, may as well let it go until you can plug the big open hole that lets rain enter the car.
pswayze
Jun 30, 2016 12:52 PM
Cmillett138
Jun 29, 2016 08:17 AM
carid
Jun 7, 2016 08:24 AM
darthtony360
May 1, 2016 09:58 PM
